Tractor will not start
/ Tractor will not start #1
mffarmall
Colorado
Farm Pro 2425, MF 50, JD B, Farmall Super MTA
Hey all,
Sorry about posting this. But I really am not sure where to start. Just finished the 4x4 rebuild and she won't turn over. What I have done to date and then what I don't see happening.
1. New battery (825 700cc) not 900 but could replace with free trade in.
2. cleaned all connections + and - even ground and starter.
3. cleaned out gas bowl and primed injectors. She has been siting from Sept. when primed took 50 pumps to get fuel to come out of plunger
4. checked fuses
5. Used starter fluid just to help
6. Blow out air filter
What it does
Turns starter like she is weak
No smoke at all
starter heats up quick
once again, sorry about posting this before really hunting post. Looked through first few pages. But it just kills me that I have to fix it before I can see if I fixed it.
/ Tractor will not start #2
verify starter wire
If I remember correctly you only did a drive train rebuild and didn't touch the engine so I would verify clutch disengaging fully and not dragging
Not enough CC amps will definitely give the slow crank symptom verify battery is optimally charged. Not enough amps from battery can cause starter to overheat as well
Does popping your compression relief valve make it turn over easier? If so see above
Don't hit it with ether, way to volatile.. If you are at your last straw and want to help it mildly, soak a small rag with gasoline wring it out real good and stick on air cleaner. Will provide a fairly safe extra punch and will not over rev once started.
I know this is not much but also to help see possible connection issues as the culprit try to start when almost dark.. Any week connection should give off a small spark and help you identify if any are there.
Sorry not much help but I hope you find it quick
/ Tractor will not start #4
Check your hydraulic connections. Did you remove a FEL for this job?
Chris
/ Tractor will not start #5
In order to make the advices effective, lets separate an engine start failure into 2 steps:
1/ Does starter turn engine freely in neutral gear?
2/ Does engine not start while being freely turned by a starter?
If starter heats up quick, check the +wire (thick one) on a starter if it's not loosen first, like Rick has stated. When you provide correct turning of engine by starter, then it needs to go further.
Keep us up to date.
/ Tractor will not start #6
Rebuilt engines can often be very stiff. Dad often had to tow his tractors to start them. Won't work with hydro tractors though.
May need a heftier battery or a jump with one. Wa11banger had some good suggestions.
Maybe squirt some oil into each cylinder? Maybe an aerasol like with WD4 would work the best.
Ralph
Sorry if Im not complete, in the car. But yes I took off fel and the starter got hot fast. The hydrolic lines shake when turn key. How do you releace the presure in the line.
The engine will not turn. I dont feel the pistons move
/ Tractor will not start #9
ok so for clarification.. Was it turning over just slow to begin with and now not turning over is a new symptom?
/ Tractor will not start #10
Are the two lines connected to each other? There needs to be a path from the pump to complete the circuit. The pump moves a constant amount of fluid per revolution, without a path the pump jams. That's what people mean by "deadheading." On my Jinma the starter can't overcome a deadheaded pump.
1997 Wilson Pacesetter 8'x42' Hopper Bottom (A60462)
1997 Wilson...
Toro Three wheeler sand pro (A56859)
Toro Three wheeler...
2021 John Deere 1025R (A60462)
2021 John Deere...
AGT Industrial M-DGR (A60463)
AGT Industrial...
ASSET DESCRIPTIONS & CONDITION (A59908)
ASSET DESCRIPTIONS...
Forward 10,000lb Two-Post Electric Auto Lift (A55851)
Forward 10,000lb...
