Tractor Versus Crawler
/ Tractor Versus Crawler #1
Anonymous Poster
Epic Contributor
I have been reading the posts on this forum for a couple of weeks and this is my first post.
I am planning to purchase either a Kubota compact tractor or a Magnetek crawler with a backhoe and FEL. I would be using this equipment in the mountains of NC.
I would appreciate receiving input regarding the pros and cons of both pieces of equipment.
/ Tractor Versus Crawler #2
Crawlers are great for hilly and rough terrain. They play heck on your lawn and driveway though.
/ Tractor Versus Crawler #3
Tractor; Great versatility, larger market if you are interested in re-sale, probably much better service and parts availability.
Crawler; Gobs of traction, true front blade performance, and no flat tires. However, undercarriages, drive mechanisms, etc. are not cheap or easy to fix.
/ Tractor Versus Crawler #4
key thing to remember on crawlers are they are not designed to travel long distances. The undercarriage is the main wear item unlike wheels which basically will just travel until you wear the tread off. Crawlers are a lot more stable on slopes (usually have a lower center of gravity and wider "footprint") so a lot depends on what YOUR use is going to be.
/ Tractor Versus Crawler #5
oldud,
What part of the mountains are you from. I'm in Etowah.
Eugene
/ Tractor Versus Crawler #6
What do you plan to use it for? I use a 4wd tractor in the NC mountains near Boone for general road maintaince,bushhogging and landscaping. If you will be mainly moving dirt and rough grading then the crawler will greatly out work the CUT, and be much more stable. The CUT is not as specialized as the crawler, but can probably do a larger variety of task.
We have a place on the North Fork of the New River about eight miles north of Jefferson off Highway 16.
I will probably use it most for digging and moving dirt, rocks, etc. Don't plan to use it for cutting grass. What does CUT stand for?
/ Tractor Versus Crawler #9
Oldud,
CUT=Compact Utility Tractor
3269 (A63117)
3269 (A63117)
2014 Chrysler 200 Sedan (A64557)
2014 Chrysler 200...
2005 Ford F-450 Dump Truck, VIN # 1FDXF46P65EB16866 (A65563)
2005 Ford F-450...
2017 Nissan Altima 4 door (A63689)
2017 Nissan Altima...
2022 EZ-GO ELITE...
10 ft bed. 14 ft trailer (A61567)
10 ft bed. 14 ft...
