Tractor use percentages
/ Tractor use percentages #21
95% Moving dirt/gravel (maneuer ) with my Ford 660
05% Moving stuff with FEL(mulch, old dog houses, refridgerators, etc...)
??% Idling while your doing something else and start up and cool down).
I figure that applies to all my tractors for a few percent here and there.. hard to gauge.
100% Bush Hogging with my NH 7610s
50% Plowing/tilling with the 8N
50% Ag (hay, planting) ( seeding) with the 8N
??% Driveway maintainence
Not yet.. but soon one of the old girls is gonna be doing some driveway maintenance.. just havn't decided wich of them gets the honor yet..
Soundguy
/ Tractor use percentages #22
An interesting thing about owning a tractor is seeing how versatile they are when your needs and ambitions change. How I needed to use it before finish grade was completed a couple of months ago and now is considerable.
Of course, acquiring new implements (like the bush hog) adds to the changing uses!!!
Before Finish grade:
70% front loader work
15% box blade driveway maintenance/grading
10% tilling (use this quite a bit)
5% sub soiler and potato plow/middle buster
Now:
60% bush hog
15% front loader work
10% box blade
10% tilling
5% subsoiler and potato plow
/ Tractor use percentages #23
For the Kioti:
00% Chipping (if you have a PTO chipper)
45% Moving dirt/gravel
10% Back Hoe work (doesn't really take that much time!)
10% Finish grading
00% Snow work
05% Idling while your doing something else and start up and cool down).
00% Finish Mowing
03% Bush Hogging
00% Digging with the FEL
00% Mixing concrete (if you have a PTO mixer)
00% Plowing/tilling
00% Logging
00% Ag (hay, planting)
00% Spraying
10% Driveway maintainence
02% Post holes
10% Riding Ring maint. (Arena Harrow)
The Ferguson is 100% Brush Hog. And maybe a little bit of running it just to hear the way it sounds!
/ Tractor use percentages #24
40% Moving dirt/gravel
00% Back Hoe work
01% Moving stuff with FEL(mulch, old dog houses, refridgerators, etc...)
05% Finish grading
05% Snow work
04% Idling while your doing something else and start up and cool down).
00% Finish Mowing
03% Bush Hogging
10% Digging with the FEL
01% Plowing/tilling
29% Logging
01% Ag (hay, planting)
00% Spraying
01% Driveway maintainence
Anything else
Does doing the yard with the brush hog right after I sharpened it count as finish mowing?? /forums/images/graemlins/grin.gif It did a good job, the chains were a little rough on it in the tight turns /forums/images/graemlins/shocked.gif
/ Tractor use percentages #25
Here are mine:
02% Chipping (if you have a PTO chipper)
05% Moving dirt/gravel
00% Back Hoe work
10% Moving stuff with FEL(mulch, old dog houses, refridgerators, etc...)
02% Finish grading
00% Snow work (Don't understand the concept of snow)
01% Idling while your doing something else and start up and cool down).
60% Finish Mowing
10% Bush Hogging
02% Digging with the FEL
02% Plowing/tilling
00% Logging
02% Spraying
02% Driveway maintainence
Anything else
02% PTO Generator
/ Tractor use percentages #27
For me right now it's;
05% Back Hoe work
02% Snow work
00% Finish Mowing
00% Bush Hogging
00% Plowing/tilling
85% Logging
00% Spraying
Anything else
Although if any IRS representatives happen to be out there it's;
100%Logging
00%Anything else
/ Tractor use percentages #28
Here is mine:
00% Back Hoe work
05% Snow work
65% Finish Mowing
20% Bush Hogging
00% Plowing/tilling
00% Logging
00% Spraying
00% Driveway maintainence
/ Tractor use percentages #29
00% Chipping (wish I had one - PTO chipper)
30% Moving dirt/gravel
20% Back Hoe work
20% Moving stuff with FEL(mulch, old dog houses, refridgerators, etc...)
00% Finish grading
25% Snow work
00% Finish Mowing
04% Bush Hogging
00% Plowing/tilling
00% Logging
00% Spraying
2025 Kubota SVL75-3HFWCC High Flow Cab Track Loader - 70 hours
2025 Kubota...
2013 FORD F-250 SUPER DUTY (A65643)
2013 FORD F-250...
2006 TerraGator 8104 (A63688)
2006 TerraGator...
2002 Jeep Wrangler (A64127)
2002 Jeep Wrangler...
EZ-GO SHUTTLE 2X2 TXT GAS GOLF CART (A63276)
EZ-GO SHUTTLE 2X2...
Great Dane Van Trailer 1989 (A63689)
Great Dane Van...
