Tractor use percentages
/ Tractor use percentages #21
95% Moving dirt/gravel (maneuer ) with my Ford 660
05% Moving stuff with FEL(mulch, old dog houses, refridgerators, etc...)
??% Idling while your doing something else and start up and cool down).
I figure that applies to all my tractors for a few percent here and there.. hard to gauge.
100% Bush Hogging with my NH 7610s
50% Plowing/tilling with the 8N
50% Ag (hay, planting) ( seeding) with the 8N
??% Driveway maintainence
Not yet.. but soon one of the old girls is gonna be doing some driveway maintenance.. just havn't decided wich of them gets the honor yet..
Soundguy
/ Tractor use percentages #22
An interesting thing about owning a tractor is seeing how versatile they are when your needs and ambitions change. How I needed to use it before finish grade was completed a couple of months ago and now is considerable.
Of course, acquiring new implements (like the bush hog) adds to the changing uses!!!
Before Finish grade:
70% front loader work
15% box blade driveway maintenance/grading
10% tilling (use this quite a bit)
5% sub soiler and potato plow/middle buster
Now:
60% bush hog
15% front loader work
10% box blade
10% tilling
5% subsoiler and potato plow
/ Tractor use percentages #23
For the Kioti:
00% Chipping (if you have a PTO chipper)
45% Moving dirt/gravel
10% Back Hoe work (doesn't really take that much time!)
10% Finish grading
00% Snow work
05% Idling while your doing something else and start up and cool down).
00% Finish Mowing
03% Bush Hogging
00% Digging with the FEL
00% Mixing concrete (if you have a PTO mixer)
00% Plowing/tilling
00% Logging
00% Ag (hay, planting)
00% Spraying
10% Driveway maintainence
02% Post holes
10% Riding Ring maint. (Arena Harrow)
The Ferguson is 100% Brush Hog. And maybe a little bit of running it just to hear the way it sounds!
/ Tractor use percentages #24
40% Moving dirt/gravel
00% Back Hoe work
01% Moving stuff with FEL(mulch, old dog houses, refridgerators, etc...)
05% Finish grading
05% Snow work
04% Idling while your doing something else and start up and cool down).
00% Finish Mowing
03% Bush Hogging
10% Digging with the FEL
01% Plowing/tilling
29% Logging
01% Ag (hay, planting)
00% Spraying
01% Driveway maintainence
Anything else
Does doing the yard with the brush hog right after I sharpened it count as finish mowing?? /forums/images/graemlins/grin.gif It did a good job, the chains were a little rough on it in the tight turns /forums/images/graemlins/shocked.gif
/ Tractor use percentages #25
Here are mine:
02% Chipping (if you have a PTO chipper)
05% Moving dirt/gravel
00% Back Hoe work
10% Moving stuff with FEL(mulch, old dog houses, refridgerators, etc...)
02% Finish grading
00% Snow work (Don't understand the concept of snow)
01% Idling while your doing something else and start up and cool down).
60% Finish Mowing
10% Bush Hogging
02% Digging with the FEL
02% Plowing/tilling
00% Logging
02% Spraying
02% Driveway maintainence
Anything else
02% PTO Generator
/ Tractor use percentages #27
For me right now it's;
05% Back Hoe work
02% Snow work
00% Finish Mowing
00% Bush Hogging
00% Plowing/tilling
85% Logging
00% Spraying
Anything else
Although if any IRS representatives happen to be out there it's;
100%Logging
00%Anything else
/ Tractor use percentages #28
Here is mine:
00% Back Hoe work
05% Snow work
65% Finish Mowing
20% Bush Hogging
00% Plowing/tilling
00% Logging
00% Spraying
00% Driveway maintainence
/ Tractor use percentages #29
00% Chipping (wish I had one - PTO chipper)
30% Moving dirt/gravel
20% Back Hoe work
20% Moving stuff with FEL(mulch, old dog houses, refridgerators, etc...)
00% Finish grading
25% Snow work
00% Finish Mowing
04% Bush Hogging
00% Plowing/tilling
00% Logging
00% Spraying
John Deere 15' PT Batwing Mower (A64126)
John Deere 15' PT...
2001 INT 4900 DT 530 (A62679)
2001 INT 4900 DT...
2006 Toyota Sierra CE Van (A61574)
2006 Toyota Sierra...
2004 COMBILIFT CL30060LA45 FORKLIFT (A63276)
2004 COMBILIFT...
17394SFL (A61568)
17394SFL (A61568)
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A61567)
Pallet of...
