Tractor trailering
/ Tractor trailering #11
IF you are in your home town, and in a safe place to drive, I'd drive the tractor the two miles. I've driven mine 10 plus miles through town with my slow moving vehicle plate on the back of the tractor. I called the police and explained what I was doing and they were good.
If you know your police department, and you are being safe, and you are going to your daughters I'd expect you are good to drive.
Just my opinion. I've driven my tractor around a few times and have never had trouble with my local police, like previous poster, I've driven by officers and they've just let me pass on by. Could be just a benefit of living in a small town.
Joel
/ Tractor trailering #12
Same as above, for me. I don't know any of the officers, but have passed a lot of them. I run with lights on, flashers going up until I need a turn signal, and keep track of the traffic behind me. Even though I technically have the right of way, I take the opportunity to pull over when there's a little ramp or apron. This is mainly to keep someone in back of me from trying to pass in an iffy spot. Normally, I keep my right tire just on the right edge of the road, leaving enough room for the cars behind me to see easily, and they usually go around, even on a double yellow line.
/ Tractor trailering #13
If you don't want to drive, rent a small trailer like was suggested. See how you like it, you may find it to be a good test for a possible trailer purchase later on. I don't think I'd use a 2 wheel dolly, just me being nervous but tractor tranny's are expensive!
Let us know what you decide.
/ Tractor trailering #14
I agree with Jimmy and island, i'd definately not dolly the tractor.
Can't imagine tractor bearings being designed for any kind of speed at all.
Joel
/ Tractor trailering #15
Could you "mow" the right-of-way along those two miles?:p No need for a trailer and you aren't on the road:D
/ Tractor trailering #16
I drive my CK25HST on the paved roads all the time. Make sure your on 2 wheel drive. My front tire show some wear but that is due to loader work. Rear industrial tire still look brand new at 440 hrs. and about 50 miles of pavement.;)
All great replies, after talking to a few people, I think the two wheel dolly has the potential to screw up the HST so that is out.
Yes I am in a small town and yes I know the chief of police, so that is an option.
Best option is a landscape trailer for that short distance my F-250 will handle that pretty easily. Then I will have the trailer if I need to take the tractor for service. One more piece of equipment to store- sure to aggravate the boss.
I will look on Craig's list for something in CT.
/ Tractor trailering #18
I think I'd talk to the chief of police before buying the trailer. While a trailer is nice to have, and a down right necessity sometimes, it is a lot of work loading, chaining, unchaining, unloading and then back again when you are done. I've only trailered mine a few times. But, each time it wears me out just getting it shackled onto the trailer (usually 4 chain/binder pairs). Even though I own a trailer, in a situation like yours, I'd choose driving everytime, especially if I got some tacet approval from the COP.
Also, don't forget to factor chains and binder into your trailering costs. Probably about $200. Most states are pretty strict about proper chaining. If you don't do this right, you may end up still paying a traffic ticket.
/ Tractor trailering #19
I need to move my ck20hst about 2 miles to my daughters house. Here in CT it is against the law to drive your tractor on the highway unless you have it registered to a farm and then you can only move it from one field that you own to another field that you own. Since I may have to do this fairly often and a 3-6 ton trailer is pretty expensive, I was wondering if anyone has used a two wheel car dolly to move their tractor a short distance? Any problem towing the HST if it is in neutral? The FEL would have to be up above the pickup truck bed to get close enough to load it and tow it. The Farm Bureau suggested I chance it and just put the hazard lights and SMV sign on and drive it over during slow traffic times.
Just a couple thoughts. You say you may be doing this fairly often, everybody needs a trailer any way, your tractor won't require that big of a trailer.
Are you SURE you wouldn't really just be better off with a trailer?
Once you have it you'll use it more than you think you will now.
Sorry Gil, I didn't read the last page before making my comments. Good luck on finding a good trailer.
/ Tractor trailering #20
Gil
You mentioned it was against the law in your state to drive on the road, what happens in the event of an accident? Would your insurance cover you? Would it cover the other party ? Just something to think about.
Harvey
2018 Kubota SVL95-2S (A60462)
2018 Kubota...
Mower King Brush Cutter (A53317)
Mower King Brush...
2005 Suzuki King Quad 700 Fourwheeler (A61166)
2005 Suzuki King...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
2007 Ford F-750 2,000 Gallon Water Truck (A60352)
2007 Ford F-750...
2019 KUBOTA SVL75-2 SKID STEER (A62129)
2019 KUBOTA...
