Tractor Supply 3tph Post Hole Digger
/ Tractor Supply 3tph Post Hole Digger #1
Lutzy48
Miles City, MT
Ford 1710
Does anyone know what the Tractor Supply 3tph Post Hole Digger weighs (without the augers)? It is not listed on the internet and a call to the store was unsuccessful. Thanks.
/ Tractor Supply 3tph Post Hole Digger #2
I believe that the current CountyLine model is a re-branded SpeeCo Model 65. Maybe you can find the specs for that model easier.
/ Tractor Supply 3tph Post Hole Digger #4
Don't know about the weight but I bought the TSC PHD and it worked great. 9" Auger in hard soil and it did the job. Good luck
/ Tractor Supply 3tph Post Hole Digger #5
I have a similar unit built by Worksaver I think. I've replaced the teeth once and and the auger once(12") About 500 holes through red clay and rocks. Plan on another 100 this fall. I did weld on brackets to add extra weight.
/ Tractor Supply 3tph Post Hole Digger #6
I have a TSC Post hole digger. I didn't weight it. I can guess about 130 to 150 lbs. I been using a 12" auger and did 75 holes in hard pack dirt and rock. No problem beside have to get the large rocks out by hand.
SpeeCo makes the Post hole digger for TSC.
/ Tractor Supply 3tph Post Hole Digger #7
Usually you can handle them if you mount the frame onto the 3pt hitch, then the gearbox assembly and PTO shaft. I keep mine vertical with an overhead chain, and position the frame at just the right height so I can swing the auger over and pin it. More weight is good!
The TSC is not the same as the SpeeCo. The one thing that drew me to the TSC over the others at the same price point was the extra reinforcement it has in the high stress area. It has a huge gusset where the yoke attaches to the boom. Thanks for all the replies.
/ Tractor Supply 3tph Post Hole Digger #9
I guess it depends on your area. Here, the TSC PHD is made by SpeeCo.
The website photos on TSC show the SpeeCo. TSC's other supplier based on area is Tarter... their PHDs look nothing like it.
/ Tractor Supply 3tph Post Hole Digger #10
The 65 shows a weight of about 140 lbs, the HD is a little bit heavier. The TSC model is somewhat of a combination of the 65 and HD, not sold as SpeeCo. I would guess that the TSC would be about 155 lbs.
/ Tractor Supply 3tph Post Hole Digger #11
I'm 100% sure my TSC Post hole digger is a Speeco. I had the gear box warranty. Speeco did it for me.
/ Tractor Supply 3tph Post Hole Digger #12
Yeah, it's just that TSC has multiple suppliers for CountyLine. IE, the box blade here might be KK, but on the west coast it could be Tarter. I didn't think they bought Tarter PHDs though, just Speeco... but I could be wrong.
/ Tractor Supply 3tph Post Hole Digger #13
I just bought one from TSC in Delaware and it is a Speeco PHD also. I would guess about 150 lb without the auger. It is a nice unit. I got it on sale without any sales tax for 560$ with a 9" auger.
/ Tractor Supply 3tph Post Hole Digger #14
I purchased one on sale plus a 10% off coupon last fall, its still in its crate. In Maine the TSC attachments are usually from Tarter, but the PHD is a SpeeCo. The model I have matches up to the website.
SpeeCo customer service might be able to help get the exact weight.
1-800-525-8322
Model No. S24045500
/ Tractor Supply 3tph Post Hole Digger #15
The TSC Post Hole Digger is this Speeco unit Content Page
I just bought one awhile back. I called Speeco about their down force kit (decided to go with bar bell weights bolted through the hole in the arm) and they told me their parent company makes them for them and TSC along with others. Call TSC again and ask for the shipping weight on the item and take about 25 lbs off for the crate.
/ Tractor Supply 3tph Post Hole Digger #16
We have a TSC post hole digger and 12" auger. Dug about 80 holes since buying,very pleased. It is made by SpeeCo.
Thanks for all the feed back. I just got back from TSC with the post hole digger. It was $50 off today. Yipee. FWI, the back of the instructions has the SpeeCo label. I'll pick up the augers in Montana when I arrive there next month. I need a 6" for posts and the 12" for some footings.
/ Tractor Supply 3tph Post Hole Digger #18
Should have listened to us :)
/ Tractor Supply 3tph Post Hole Digger #19
Looking to buy a PHD for put up some poles. The TSC PHD is in stock at the local store, any other brand of PHD is going to be an order and ship.
The price point on the TSC PHD is good and the plus of being local.
Since most that have posted here on this thread has had experience with the TSC PHD, I would like to know if you would recommend the TSC PHD? Are they built sturdy and if there are any complaints to be had about them.
/ Tractor Supply 3tph Post Hole Digger #20
I have a TSC Post Hole digger. It's a well built unit and work well on 75 holes. I just need a few sheer bolts.
