Tractor step
/ Tractor step #1
magicheater
central Wisconsin
Kubota B7800, B26 TLB
Had no step on the right side of my tractor. Finally got around to making one. Actually made one for each side as will replace the almost unusable one on the left side next. I modified the throttle lever to facilitate easier ingress/egress on the right side. Bracket is 1/4" material which I got lucky and got powder coated. The top piece is an old aluminum diamond tread deck plate off a Komori printing press which I cut in half to be able to do both sides.
/ Tractor step #3
Nice job on both tasks!!
I'm really surprised that big Kubota didn't have a step though.
/ Tractor step
Thanx! to Jay also. Most Kubotas are made to enter from the left side only, at least the two I own. Practicality dictates both sides for on/off, hence the mods. Still on the fence about modifying the FEL joystick on either tractor. When working in cold weather the extra clothing is usually what catches on the various handles and knobs. An unanticipated use for the wide steps is for an unauthorized passenger. Not much room on these Kubotas for riders as they pack a lot into a little bit of space.
/ Tractor step #7
Both of you did nice work on your respective steps.
I looked at Stonehaller's link, and I can see why he made the filter guard as those puppies are sitting ducks.
/ Tractor step #8
Tractors like horses should be mounted on the left side. Just like lawn mowers, the grass shoot is almost always on the right and you should never mount from the right. On most tractor all the controls are on the right and that makes it darn near impossible to get into positions without pulling hoses or levers.
I guess it was drilled into me when I was a about 10 and started mowing the yard. Dad saw me get on the lawn tractor from the right side. I ended up mowing for a little while standing up. Just my 2 cents.
Wedge
/ Tractor step #10
I wish the step on mine looked as nice as that. One thing you might add is something to give you a sure grip when you have wet or muddy boots. I'd be afraid of stepping off onto that and losing my footing. Maybe a piece of expanded aluminum or ss on top of the step would help. It might be fine as is though. Just a thought.
/ Tractor step #11
Nice step - On my L3830 the HST pedal is in the way if you get in from the right. If it is in gear you could go for an unexpected ride!
/ Tractor step #12
Wedge
Right on wedge40. From the early agrarian days, all pulling livestock if mounted were mounted from the left "on side". Even the early stock pulled riding attachments were of the same mounting side and so were the first tractors. From an early selling standpoint it was a good crossover move.
/ Tractor step #13
I hear what you're saying, but we get on ours from both sides just to play with their heads. You get some strange looks when you do it though, "What in the hel* are they doing now ??" And that's from the horse, never mind any onlookers. Try leading one from the right side sometime, I did it this morning just for the hel* of it. A few odd looks, and he settled in and walked along.
Chilly
Wedge
/ Tractor step #14
Nip 'er off about 5 inches. I finally cut mine and am happy with the result. Still hooks under a loose coat though unless I'm careful, but getting on in the woods is ever so much easier now. I used to really hate walking around to get on from the left, and sometimes it just made life more difficult than it needed to be.
Chilly
/ Tractor step
Guess I just saw the utility of changing the "genetic" habits.
2022 EZ-GO ELITE...
Kivel Quick Hitch Mini Skid Steer Attachment (A61572)
Kivel Quick Hitch...
2016 Ford F-550 4x4 Venturo ET25KXX 2 Ton Crane Service Truck (A61573)
2016 Ford F-550...
CASE 610 Sprayer System 2000 Gallons (A63688)
CASE 610 Sprayer...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A61572)
2025 Kivel 48in...
Sterling AT (A63689)
