Tractor starts but dose not keep running
   / Tractor starts but dose not keep running
Typically, the ballast resistor is only in the circuit during "Run". In "Start" position, the coil gets full voltage while cranking. If it starts then dies, it may well be a bad resistor.
Ok. Will check that. Thanks
   / Tractor starts but dose not keep running #13
A bad (open) ballast resistor it will have spark while cranking only. No spark in run. So if it cranks up and continues running in run position even a few seconds, the ballast is OK. If it runs while cranking, dies in run I would suspect ballast.
   / Tractor starts but dose not keep running #14
There is a fuel filter in the banjo fitting where the line attaches to the card. Other common carb problem is bad accelerator pump. The S650 is not gravity fed & has a fuel pump. the fuel system is not pressure regulated
Heil V-1722 28Yd Front Loader Garbage Truck Body (A51691)
Heil V-1722 28Yd...
2004 INTERNATIONAL 9400I DAYCAB (A55745)
2004 INTERNATIONAL...
2025 Raytree RMPP680 Post Pounder Skid Steer Attachment (A53425)
2025 Raytree...
2019 International DuraStar 4300 24FT Box Truck (A53422)
2019 International...
2008 ATOKA TRAILER & MFG. ATOKA TRAILER & MFG. (A53843)
2008 ATOKA TRAILER...
2016 Ford Fusion SE AWD Sedan (A53424)
2016 Ford Fusion...
