Tractor stalls when brake is applied.
   / Tractor stalls when brake is applied. #1
JFulford
Kioti CS2520
Tractor is new and the engine is stalling out if the brake is applied while tractor is in gear. Is this normal behavior? I wouldn’t expect it is but not seeing much in the manual about it. Sorry for the noob question, thanks in advance.
   / Tractor stalls when brake is applied. #4
Oh, ok, i thought you told it was in gear, so manual trans come to mind.
By in gear I mean not in neutral and in either Low or High range. Sorry should have been more clear.
   / Tractor stalls when brake is applied. #6
Is the pedal not returning to neutral when you take your ft off it ?
   / Tractor stalls when brake is applied. #7
Are you jamming on the brake while still standing on the HST pedal? I rarely use the brake just use the HST to slow or stop, brake only when holding position on steep hill or inching nose down into really steep place.
My little BX used to almost throw you onto the hood if you let of the HST pedal to fast. :rolleyes:
   / Tractor stalls when brake is applied. #8
Sorry for misunderstanding. Being a guy with a stick, lol, I have no experience with HST, but to me it does not sound normal.
I was applying the brake while sitting still. No other pedals pressed. Engine was at lowest throttle level, HST in low gear. I applied the brake pedal and it pretty quickly stalled.
Giyi 46" Mulcher (A53316)
Giyi 46" Mulcher...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
2011 DOOSAN G25KW GENERATOR (A55745)
2011 DOOSAN G25KW...
2005 FORD F-150 XL (A55745)
2005 FORD F-150 XL...
2009 Bruton T/A Enclosed Livestock Trailer (A55973)
2009 Bruton T/A...
Honda EU3000is Gasoline Companion Inverter Generators (A54811)
Honda EU3000is...
