Tractor: spray paint or spray booth?
/ Tractor: spray paint or spray booth? #1
Builder
Super Member
East PA or 750 mi. east of a short man named Dar__
Kubota, AGCO, New Holland LB
Guys,
The previous owner dumped a load of stone backwards on the hood. No dents, just a couple hundred paint chips with little rust spots under each one. :)
I can sand & spray paint for $15 and a lot of sanding labor, or I can take it to an autobody shop and have it done for $200-$250. I don't have any shop equipment for painting. The hood is kind of the showpiece sheetmetal for the tractor.
What would you do?
/ Tractor: spray paint or spray booth? #2
Well I would just run it or if it bugged me sand and paint. I wouldn't have a shop paint it for sure. But I'm more concerned with using a tractor than looking at it, plus I'm cheap on stuff like that. Even my custom harley is only getting a $650 paint job.
/ Tractor: spray paint or spray booth? #3
Do a good job of sanding if you spray can it. I just did a so-so job and it looked good when I did it. Doesn't looks so good 4 years later.:eek: Mine was on my MF 4243 and I got something on the hood and upper side panels that was taking the paint off.
I'm the same way, too, or I wouldn't do this stuff for a living, but I don't like the idea of letting my hood go to crap and have rust holes in it in another year. It's a $70K machine (new) and with my pickup "only" costing $40K new, I wouldn't le the pickup hood look like that either.
I have been able to do some pretty nice work with a spray can, but it never seems to last.
/ Tractor: spray paint or spray booth? #5
Being somewhat **** about such things, I'd fix it right, particularly if it's the only cosmetic problem with the tractor. The way I look at it is this: Even if the previous owner was a little careless, you won't be, so why not have it the way you want it for the duration of your ownership? Also, it won't hurt the resale value.
/ Tractor: spray paint or spray booth? #6
Sand it, primer , paint with spray cans( several light layers) and then use a good clear coat in a can. I have done many jobs like that and they still look good years later. spray paint is almost like regular paint you just have to apply it a little different. You could fix it yourself for probably $30 and a little labor.
Just a note: I was at Lowes yesterday and they now have JD green/yellow in spray cans labeled at tractor paint. Neat.
I fix things right but, if it is not a brand new tractor then fix it yourself.
Bill
/ Tractor: spray paint or spray booth? #7
If it is the hood from a full size Case tractor, $200-250 would be a little cheap.
I would be able to sand it down and blow some paint on it for that. But, if it has a lot of chips, removing all the paint in the affected areas, (easier than feathering then all out), can be a time consuming process. Then to refinish it with quality material so it holds up, I'm guessing $250-350, would get you a "like new" hood. (The really tough paint is expensive).
Unless your, real particular or, going to baby it, I think I would leave it go. Have some touch-up work done on it when you sell it, that way it looks its best when it really needs to.
Just got an offer from a local refinisher of equipment (biggest guy around) to blast it, primer it and paint it with the good urethane paint from PP&G for $175. I actually have a matching cowling that's not damaged, just faded, and he said he'd do that with no extra charge. So that was too much for me to turn down.
I'm $175 poorer, but I think it'll enhance my happiness, the looks and the resale value of the machine.
Thanks for your suggestions.
/ Tractor: spray paint or spray booth? #9
The shops out by you must be slow. That's a darn good price.
/ Tractor: spray paint or spray booth? #10
I feel better already.;)
/ Tractor: spray paint or spray booth? #12
This is both cheap and easy, if time consuming to do yourself.
1. get a QUALITY sanding/filling primer from a auto/paint store.
2. power sand out all the dings
3. spray the filling primer twice, then sand with 320
4. repeat 3 twice, maybe moving to 600 grit
5. when you cannot see/feel imperfections (wear gloves!), then several light coats of the matching paint. My hands down favorite is Van Sykle, lots of solids in that paint.
6. sand with 600 to 800 between next to last and last coat
7. clear coat if you wish.
warning, this will make everything else, including any Japanese or American car look shabby.
Builder said:
Guys,
What would you do?
/ Tractor: spray paint or spray booth? #13
If I did it for cost, I could not do it for that price.
Tsterkel, you forgot some sort of etch before primer.
/ Tractor: spray paint or spray booth? #14
ray66v said:
If I did it for cost, I could not do it for that price......
Same here!
Using PPG epoxy primer, K36 primer and a Urethane, Poly-urathane or even Acrylic enamel and including the specific hardeners and reducers would put me over $200. in materials alone (and I didn't even mention CC).
You got a hellava deal :D.
/ Tractor: spray paint or spray booth? #15
You made the best choice; will be done right; paint will hold up better than spray cans .
/ Tractor: spray paint or spray booth? #16
Forget about how it looks, you need the protection. If rust spots and rust holes are not in your future plans, then you should get it fixed and fixed right. The spray can route, clear 2nd coat or not, is NOT equivalent to having it painted by a professional. It's in the quality of the paint.
Most paint jobs today are done using 2 part paints (epoxy) and goes on hard. They are quite expensive because the paint is expensive. If your body shop is going to shoot acrylic enamel, insist on the catalyzed stuff.
I shot the back of my tow truck myself years ago and it wasn't a great job. Had orange peel all over and it was Orange color to boot. Once it was dry, I thought no problem, I'll just sand it flat but it was HARD AS ROCK. Needless to say, I left it alone and the paint was about as durable as powder coating, maybe better. As you know, we throw chains, floor jacks, all kinds of equipment on the bed and it held up well.
You can do it yourself. Bring a sample of your color to the paint shop (the places that sell auto body paint, not Kelly Moore) and they will mix it for you. Ask for Catalyzed Urethane Enamel. Buy and mix hardener into it just prior to painting. Being that it is equipment and not a show car, you can paint it using an el cheapo craftsman or HF brand. For the latter, I might not even bother to clean it afterwards and just toss it. This should result in a much more durable paint job than 100 coats of spray can paint. As for looks, well that depends on your skill level. In the end, it might just be easier to detach the hood and have your body shop do it for $200. Just make sure they use the good stuff. You need it for the durability.
That's what I thought, for $175, even if it's just a decent job, I'm doing OK.
/ Tractor: spray paint or spray booth? #18
Pay a bit more and have a top coat of stone guard or chip guard (some such name) sprayed on top of the color coat. It's a thicker clear coat that is more pliable and able to resist stone chips. Often used behind the wheel wells of trucks.
jb
/ Tractor: spray paint or spray booth? #19
jb
The product the manufacturers are currently using for clear stone gaurd is a vinyl self adhesive material. The material alone for something that large, from 3m, (the best version), would cost more than the $175 he is paying. There is no "spray on" version that works. Proper metal prep, etch, and a high quality urethane epoxy primer and paint in a "wet on wet" application would be the most durable finish for this application.
The hood already has a spot around the lock hasp that has this self adhesive material applied to it so my lock wont scratch the paint.
I guess I'll be losing this feature in the prep phase. :(
2025 Stump/ Trench Bucket Mini Skid Steer Attachment (A56857)
2025 Stump/ Trench...
2012 ISUZU NPR CREWCAB 16FT BOX TRUCK (A59905)
2012 ISUZU NPR...
2000 Bobcat 763 (A60462)
2000 Bobcat 763...
2022 Takeuchi TL12R2 (A60462)
2022 Takeuchi...
2020 INTERNATIONAL LT625 6X4 TANDEM SLEEPER TRUCK (A59909)
2020 INTERNATIONAL...
2014 Chevrolet Silverado 1500 High Country 4x4 Crew Cab Pickup Truck (A56858)
2014 Chevrolet...
