Tractor Shuts down
/ Tractor Shuts down #1
crazyhorsemd
cincinnati, Ohio
2000 New Holland TN70, 1974 White 1370
Hello all...need some help
Have a 1974 White 1370 4 cyl. Diesel. Purchased 2010, has run great. Changed all filters, fluids, usual maintenance.
Past month, tractor harder to start, have to remove the oil bath air cleaner to start. Now, after running 30 + minutes, ( power good ..no issues) I see a little smoke from engine breather tube ( have seen it before in past..very minimal) then the engine losses all power, more smoke from breather and quits with a big puff of smoke from breather tube. No water in oil, antifreeze level good, oil level good, does not appear to be using more fuel than usual. The smoke does not appear as oil (it's not real thick, blue / white) One thing though, when it quits, I "think" the engine feels hotter than usual and the exhaust does not have the usual "diesel" odor, Note, I do not see puffs of smoke from the muffler. Is this a fuel issue???? I think it is but I'm not diesel mechanic
Thanks for listening
Any suggestions are appreciated
Crazyhorsemd
/ Tractor Shuts down #2
Welcome to TBN
What type inj pump does engine have? Check to be sure excess fuel that fuel system doesn't utilize is being returned to fuel tank IE is return line not plugged with debris?.
Tx Jim,
Thanks,
Not sure what type IJ pump but will check and let you know ( Sorry, I'm still learning about diesel) Do all systems have a "return line"
Thanks
/ Tractor Shuts down #4
Make sure fuel tank is vented properly also. You can loosen the cap to see if it makes a difference.
Could this be a glow plug issue? I've noticed recently that when I start the engine , the pre heater does not "pop" like it used to before turning the ignition?
Thanks Milkman,
I'm still rather new to tractors and Diesel... At start up, I turn the starter switch almost to point of ignition, hold it there for appx 10 seconds, hear a "pop" then turn a little further to start. Thought this was pre-heater??? is this the fuel shut off solenoid I'm hearing. Sorry if I appear clueless but up until 2-3 weeks, tractor always slow to start but ran great
/ Tractor Shuts down #8
Yes, could be pre heater, I think your tractor is direct injected so maybe intake manifold heater. I think I would start looking for a fuel delivery problem, plugged fuel filter or plugged fuel line, although on here, this is like shooting in the dark.
Can Am Defender (A63689)
Can Am Defender...
NEW Wolverine ADB-13-1218R, Skid Steer Auger (A62679)
NEW Wolverine...
2013 FORD F-550 SUPER DUTY (A65643)
2013 FORD F-550...
2015 Chevrolet Express 2500 Cargo Van (A61573)
2015 Chevrolet...
2022 EZ-GO ELITE...
Excavator trenching bucket- one bucket per lot (A63689)
Excavator...
