Tractor seat smells like a dumpster
   / Tractor seat smells like a dumpster #1
Atchuuu
Kubota L4330 HSTC
I have been really happy with the purchase of my L4330 with one small exception. The cloth seat in it smells like a dumpster or a rugby locker room. The cab cleaned up well but I just can't get the old dirty sweat out of the seat. It's so bad that my clothes stink after using the tractor.
Temporarily I have used a towel over the seat but that hasn't solved the issue. I don't want to use plastic of any type as that would be too hot and uncomfortable.
Rather than purchase a new seat (OEM seat is crazy expensive) I was thinking of removing the seat and washing it with a hose and soap then let it air dry. If that doesn't work maybe take it to a auto interior shop and see if they can remove the cloth and foam and recover.
If you have any suggestions by all means share them.
   / Tractor seat smells like a dumpster #2
I got a cheap seat cover from eBay to cover mine.
   / Tractor seat smells like a dumpster #3
Have you tried Febreze? I understand it to work very well on cloth truck seats.
   / Tractor seat smells like a dumpster #4
You could try a spray can of Ozium,spray it directly on the seat and let dry for a few minutes.
   / Tractor seat smells like a dumpster #5
I would scrub it down with your choice of cleaners and suck out the moisture with a shop vac.
   / Tractor seat smells like a dumpster #7
I bet it's still more sanitary than a $500.00/night hotel room!
OR, taxicab seat, theater seat, airplane seat (worse yet, tray table)
   / Tractor seat smells like a dumpster #8
Unbolt the seat, mix up 25% vinegar and 75% water mix and wash the seat. Dry the seat the best you can and let sit in full sun to kill mold.
   / Tractor seat smells like a dumpster #9
There's a product called Zorb that can work wonders. I usually pick it up at the local Lowes but you can also get it online. It really does an incredible job of eliminating funk smells.
   / Tractor seat smells like a dumpster #10
Get Spray 9 and spray it on a sponge and clean the cloth. Soak it good with the Spray 9, and make sure to mix it with lots of warm water. Air dry or use a hair dryer and repeat process as necessary until all odor is gone.
8400 GALLON POLY TANK (A52708)
8400 GALLON POLY...
(4) 235/70R16 USED TIRES (A58374)
(4) 235/70R16 USED...
2017 INTERNATIONAL LF687 DAYCAB (A58214)
2017 INTERNATIONAL...
2021 Chevrolet Silverado 2500HD 4x4 Crew Cab Pickup Truck (A56858)
2021 Chevrolet...
60"x30" ALUMINUM AND PLYWOOD ROLLING TABLE (A58374)
60"x30" ALUMINUM...
2022 Vermeer 573 (A55973)
2022 Vermeer 573...
