Tractor seat smells like a dumpster
   / Tractor seat smells like a dumpster #1
Atchuuu
Kubota L4330 HSTC
I have been really happy with the purchase of my L4330 with one small exception. The cloth seat in it smells like a dumpster or a rugby locker room. The cab cleaned up well but I just can't get the old dirty sweat out of the seat. It's so bad that my clothes stink after using the tractor.
Temporarily I have used a towel over the seat but that hasn't solved the issue. I don't want to use plastic of any type as that would be too hot and uncomfortable.
Rather than purchase a new seat (OEM seat is crazy expensive) I was thinking of removing the seat and washing it with a hose and soap then let it air dry. If that doesn't work maybe take it to a auto interior shop and see if they can remove the cloth and foam and recover.
If you have any suggestions by all means share them.
   / Tractor seat smells like a dumpster #2
I got a cheap seat cover from eBay to cover mine.
   / Tractor seat smells like a dumpster #3
Have you tried Febreze? I understand it to work very well on cloth truck seats.
   / Tractor seat smells like a dumpster #4
You could try a spray can of Ozium,spray it directly on the seat and let dry for a few minutes.
   / Tractor seat smells like a dumpster #5
I would scrub it down with your choice of cleaners and suck out the moisture with a shop vac.
   / Tractor seat smells like a dumpster #7
I bet it's still more sanitary than a $500.00/night hotel room!
OR, taxicab seat, theater seat, airplane seat (worse yet, tray table)
   / Tractor seat smells like a dumpster #8
Unbolt the seat, mix up 25% vinegar and 75% water mix and wash the seat. Dry the seat the best you can and let sit in full sun to kill mold.
   / Tractor seat smells like a dumpster #9
There's a product called Zorb that can work wonders. I usually pick it up at the local Lowes but you can also get it online. It really does an incredible job of eliminating funk smells.
   / Tractor seat smells like a dumpster #10
Get Spray 9 and spray it on a sponge and clean the cloth. Soak it good with the Spray 9, and make sure to mix it with lots of warm water. Air dry or use a hair dryer and repeat process as necessary until all odor is gone.
2016 Tesla Model S AWD Sedan (A51694)
2016 Tesla Model S...
New/Unused 30ft x 65ft x 15ft Storage Shelter (A51573)
New/Unused 30ft x...
BOMAG BW145D-40 SMOOTH DRUM ROLLER (A51246)
BOMAG BW145D-40...
Intermodel Metal Storage Crate (A51573)
Intermodel Metal...
BOBCAT 260 WELDER/GENERATOR (A52472)
BOBCAT 260...
