Tractor search
/ Tractor search #1
OSCGOLF
Omaha, NE
OK... I'm a city boy, but my wife isn't... but I'm handy with the tools.
We are searching for an acreage to have a few horses. I know, they are lots of work... We are looking for 5-10 acres and some have told me... I need a tractor, to do some work around the place... mowing, manure spreading, hay moving, snow plowing, drive maintenance and maybe gardening. One of my friends says... a Ford 8N... another friend says a 4X4 utility... personally I like the vintage tractor idea.
I was thinking about something under $5K, with a 3 point hitch, wide front and no live PTO... any suggestions/opinions from the readers?
/ Tractor search #2
You see a lot of Ford 8Ns around all over the place for $3K or so. The trick is to find one that hasn't been worked to death to the point that the engine and tranny are nearly shot.
If you can pull an engine and do a rebuild, then you have a lot more choices than someone who's not so handy.
In Jul06 I bought a 1964 Massey Ferguson 135 diesel (45 hp engine, 35 hp pto, dual stage clutch) for $3600. Something like that would get your jobs done.
Right now I'm rebuilding a 1951 Minneapolis Moline BF tractor (27 hp gas engine, 3pt hitch, single stage clutch). Got it for $1300 and have another $1600 invested in a complete engine rebuild.
Check craigslist. There are lots of used tractors in the 25-45hp range that would work for you.
/ Tractor search #3
It is really hard to go wrong with a Ford 8n. They are one of the toughest, most dependable tractors ever made, and to this day, no model has better parts availability. I have had one for about 25 years that I bought with 1200 hrs on it from the widow of the original owner. Since I gave it a valve job the second year (originals cant handle unleaded gas), it hasnt given me a bit of trouble. That old tractor will start right up quick, even when the temperature is well below zero, on the original 6 volt system. There is no modern tractor that I would rather have on my 2-row corn planter, or use for hauling firewood during the winter. Those are it's primary uses these days as my (5) newer tractors cover most of the other chores. One sure fire way to know you are getting a good engine, is to find one that starts good cold on 6 volts. 12 volt conversions are nearly always a band-aid to help a worn out engine start easier. Also, the 51 and 52 8n's are the best of the bunch with all the upgrades like proofmeter, side-mount distributer, etc.. These tractors were the most refined form of the first modern utility tractor, the Ford N. If you can find one of these in good shape for under $3000, you will probably not have any regrets. The older 9n's and 2n's had some issues like brakes on opposite sides, not enough forward gears, and lack of "position" hydraulic control. Another good thing about an N is, unlike a new tractor, you can nearly always sell them for more than you paid. In my opinion, you would be making a mistake to get any other make/model of tractor as your first one.
/ Tractor search #4
I agree with the 8N as a good tractor, I have been looking for one for almost a year now and I just bought a NAA (after the 8N) model with 1800 original hours for $1000. The guy I bought it from is a friend of my fathers and his father bought it in 1957. I have a 2005 JD 4x4 with loader but I need another tractor and the Fords are hard to beat. I don't believe you will find a 4x4 for under $5000
/ Tractor search #5
The NAA is a better tractor for brushogging than an N because it has live hydraulics, if they work. Live PTO dont mean a thing because niether N nor NAA had it and adding an overrunning coupler completely compensates for its lack ($75 at TSC). Thats where the NAA advantage ends however. The live hydraulics comes at a cost of a more trouble-prone system. It is a lot more difficult to find an NAA with functioning hydraulics than it is a bullet-proof N. Other advantages that go to the N are slightly better fuel economy and power/weight ratio. The NAA does give you a little more horsepower, but not enough to make it a real 3 plow tractor. You certainly did get a steal at $1000 however, especially if it had good tires and everything worked.
/ Tractor search #6
Whatever you decide make sure you get a front-end loader (FEL). I have a couple of horses in the pacific NW that spend much of the winter in stalls. Stalls = manure; manure = shaving; shavings + manure = SERIOUS NEED FOR FEL :). Trust me. I have an old Ford 881D (kinda like a seriously beefed up 8/9n with independent PTO) that I like, but without an FEL it's virtually useful for anything short of brushoggin, tilling, discing. . . With an FEL you'll find endless uses from digging holes, moving rocks, poppin stumps, opening your mailbox - heck, even moving manure. . . . :)
Good luck with your decision - land = Good excuse to get a tractor; tractor = more fun than you can shake a stick at. . .
P
/ Tractor search #7
All my Amish friends use the horse to do all the chores around the place and since you plan to have some anyway, it looks like that will solve your problem.
/ Tractor search #8
I agree with folks about the 8N. One other point, if you are good with tools, the 8N is much more simple engine and transmission to keep running, similar to an older car versus a current model.
If it helps with your decision, my 8N is now being rebuilt by a local tractor mechanic. He is resleeving the engine, doing a valve job, planing the head and block, going through the carb, cleaning the gas tank, putting in a tune-up kit, replacing the belts, filters and hoses, putting in a new battery, inspecting the brakes, transmission, and lift system for $1500. The price includes parts and labor for the engine, but not the parts for the items being inspected.
/ Tractor search #9
$1500 for an engine rebuild on your 8N is about what I paid to have the 4-cyl Hercules engine rebuilt on my 1951 Minneapolis Moline BF tractor a few months ago ($800 parts, $800 labor). Block hot cleaned, cylinders rebored 0.020, new pistons/rings, new valve seats to handle unleaded gas, new exhaust valves (intake valves OK), crankshaft machined 0.010 under, new bearings, reassembled to short block config.
/ Tractor search #10
Read and Read some more. Be aware of maintenance of a tractor and associated attachements such as FEL's. Just know of the extra traction of the newer 4 wheel drives vs the vintage 2 wheel drives. My own experience was "it's all about the 3 pt attachments". I heavily invested in anything that can be attached to the back of a modern tractor. I own a Jinma JM354 with NO FEL, and I don't have horses. bjr
/ Tractor search #11
edit what you said to live hyds, and live pto if possible, then forget the 9-2-8n, and step up to a NAA, ore preferably ( live pto ) a 660, 661, 860 or 861. more tractor.. more options.. newer.. just as sturdy.
the NAA + has live hyds.. the *6* models have live pto.
an 860 costs about the same as a good 8n.. and is literally 2x the tractor.
soundguy
/ Tractor search
Lots and lots of good advice and opinions...
Considering an 8n, Jubilee or a NAA... As far as the live PTO is concerned, not sure if I'm going to be doing anything that requires that.
Can you tell me what work requires it? (There is a guy here in town that has a 57 Ford 600 for about $1800, and it has live pto).
Here's a question, how do I know by year & model, which one is live or not?
Another question I have and I hope some of you that already own one can answer this, how wide of a trailer do I need to have to transport one?
Thanks again for your help everyone...
/ Tractor search #13
If you can pick up a good 8N for a reasonable price, you won't be disappointed. We've had ours 10 years and is like an old friend. Live pto allows you to push in the clutch to stop the tractor but continue to have pto engaged to drive impliments like a bush hog. An 8n's pto stops when you depress the clutch. Sound guy correct me if I m wrong but I believe 53 and up were live pto (Ford that is).
/ Tractor search #14
OSC.. and Fire.. I guess you guys missed my post directly above yours.. telling you which models had live pto... Here's a repost from a message just above yours.
soundguy""
8n ford has a hyd pump driven by the pto shaft.. it's a single plate clutch, and non live.. when you step on the clutch, pto AND hyds stops.
All fords 53+ have live hyds via an engine driven hyd pump.
starting for year/model 55 the 600/800 series, you could get a 4 spd, non live pto 640, 5 speed non live pto 650, or a 5 speed, live pto 660.. it had a 2 stage clutch. same models in the 800 series were available. pressing the clutch half way on the *6* models clutched the drivetrain, but not the pto.
why is live pto good... say you are mowing with your 8n, and come up on a hidden stump, you stomp the clutch.. and.. keep on going because the pto is trans driven and has lots of stored energy and backfeeds the transmission and the rear wheels. you'd need to stomp the clutch and shift to neutral, or kick the pto out of gear to defeat that. or run an ORC on the mower shaft to mitigate backfeeding.
with a 2 stage clutch.. when you press it half way.. the pto and drive train are decoupled.. with pto still coupled to engine.
running a small bailer would realy require a live pto.. that way if the bailer plugged, you could stop forward motion while the machine cleared.. etc.
( for the 8n and naa, there was an optional live pto add on that was basically a pinion clutch.. you could thro a lever and uncouple the diffy from t he trans without killing the pto.. kind of added a 2nd stage hand clutch to your 1st stage foot clutch.. it's rare.. 8n is manual.. naa is hyd.. )
my advice is to look at NAA+.. they are all inthe same price range as an 8n... might as well get more tractor fo r the same money..
a running 660 for 1800$.. if it really is an 860.. and runs and operates ok.. that's a steal.. nearly half price...
soundguy
John Deere 4039TF001 (A64127)
John Deere...
2021 Kubota RTVX1120 (A64127)
2021 Kubota...
2017 Hyundai Trailer (A62613)
2017 Hyundai...
Street Sweeper (A60352)
Street Sweeper...
Trailmobile Van Trailer (A63689)
Trailmobile Van...
2017 Caterpillar 308E2 (A64126)
2017 Caterpillar...
