Tractor runs hot
/ Tractor runs hot #1
EPFuller
Ford 3400 diesel
My 10 year old Mahindra has started running hot. The onset is not consistent with either the duration of run time or the actual work being done. I noticed that the radiator hose was collapsed. Would a faulty radiator cap cause this? I discovered that Mahindra will not see a water pump by itself, but rather the entire “system “ for $700 which will entail another $500+/- labor charge. Any & all suggestions appreciated!
/ Tractor runs hot #2
I believe the possibilities are :
Faulty radiator pressure cap
Deteriorating hose
Clogged radiator passages.
I would replace the radiator hoses, cap, thermostat, and flush the radiator well.
/ Tractor runs hot #3
Certainly if the hose collapses that would restrict flow. I have a Mahindra 4510 and it runs warm. Able to keep it cooler by removing the side panels. Lets heat out and air in. Also I need to blow out he radiator fins regularly and they accumulate debris. I also relocated the battery lower so there is more airflow to the radiator.
Did put in an electric push fan but removed it, did nothing to help it seemed.
/ Tractor runs hot #4
After that many years of ownership, I would say it’s time to “deep clean” the radiator.
I have had many tractors that would keep overheating as the day went on. Pressurized air would no longer cure the problem.
I’d get some “purple power” type cleaner, spray it into rad fins. Let sit a while, then flush with strong garden hose stream from both sides. Let it dry, and if really bad, repeat the process.
Pressurized air only works so long, then it’s time for a deep cleaning.
/ Tractor runs hot
Thanks, gents I will get busy with your wise words.
/ Tractor runs hot #6
How many times have you changed out the antifreeze in 10 years ? Never ? Antifreeze protect against boil over & freezing as well as corrosion and lubricates the water pump. I bet you have all s**t circulating in the system. Damage is done w/ rust etc. At very least you need all new hoses + thermostat and a flush.
/ Tractor runs hot #7
Had similar problem with 3510 a bit ago. Pulled radiator, had to wash out the fins for a long time. Placed it on top of bucket so water flowed from 'back' to front, used dawn water and fresh water at garden hose pressure (used nozzle to reduce, not full power to bend fins) and rinsed repeatedly.
MUST use flashlight from underneath to check if clean. If clean the light will come through, if not, keep rinsing.
I am experienced with this procedure and I couldn't tell it wasn't clean until using the flashlight.
I also did a system flush with distilled water and a little vinegar to remove any rust in the system. Ran it a few days like this before flushing it all out.
End of problems. Good luck!
/ Tractor runs hot
Have flushed cooling system and refilled w/ fresh anti-freeze. Awaiting new radiator cap.
Thanks for the advice!
/ Tractor runs hot
A time or 2, but apparently not enough. Thanks for this advice.
/ Tractor runs hot #10
My TYM 330 (same as 3510) has a screen in front of the radiator that slides out for cleaning. Maybe the 3510 does too?
