Tractor runs but stops
/ Tractor runs but stops #1
Willsk
Harare
Massey Ferguson
I have a tea-20 tractor when I start it it runs and stops after a minute or two but when I start without moving it it does not stop . Anyone with an idea on the problem. If I wait for 2 or 3 minutes I can start it but when I try driving it stops after 1 or 2 minutes
/ Tractor runs but stops #2
Weak spark? Check rotor arm, distributor cap, contact points, and condenser.
/ Tractor runs but stops #3
Is the fuel tank clean? Sounds like trash sloshing around in the tank and cutting off fuel flow.
/ Tractor runs but stops #4
Check for a good flow of fuel to the carb. If you have a good flow to there, remove the brass elbow going into the carb., where the fuel line attaches. There is, or should be a fine mesh strainer screen attached. These can plug with dirt, and cut off fuel flow. Your's may be partially plugged, and allowing a bit of fuel through. Enough to refill the bowl, but not enough to keep it running for an extended time.
A can of spray carb. cleaner, with the plastic nozzle will clean them up in short time.
/ Tractor runs but stops #5
I agree definitely sounds carb related. Could be gunk in the lines as mentioned before or you might the float sticking in the carb and not dropping the needle valve completely so you are getting restricted flow to bowl of the carb.
2020 Hyundai Sonata Sedan. (A61574)
2020 Hyundai...
COLEMAN POWERMATE 60 GALLON AIR COMPRESSOR (A64281)
COLEMAN POWERMATE...
2021 CATERPILLAR 305E2 CR EXCAVATOR (A64279)
2021 CATERPILLAR...
UNUSED SDLANCH SDLL580 RIDE ON SKID STEER (A64280)
UNUSED SDLANCH...
2022 John Deere DR16 Planter (A63111)
2022 John Deere...
2008 GMC Yukon XL SUV (A61574)
2008 GMC Yukon XL...
