Tractor rim capstan winch??
   / Tractor rim capstan winch?? #21
Here is a couple of pictures of the one I built.
David from jax
   / Tractor rim capstan winch?? #22
I wasn't going to post today, but it's my 1 year anniversary of the delivery of my tractor (see siggie)! :cool: :D
@ Egon:
So with the snatch block, uh, I'll confess ignorance. Obviously I wrap rope or cable around it, then I can take my choice of lowering from above or pulling from below (mechanical advantage of 2 on the force). But then, what do I pull with? I have a 1500/3000 lb hand operated racheting rope haul, but I was trying to figure a way to use 18 hp of diesel (or 14 at the PTO) to save me'poor arms!
So I'm still faced with reeling a cable in & out with some type of tractor-mounted winch, or just hooking up the cable in some fashion and driving the tractor the necessary distance - or are you saying that the snatch block could also be anchored and used to change the direction of rope travel as I need to make the pull? That'd make sense, I may just have answered my own question! :eek:
Anyway, I've enjoyed my sporadic first year of posting, and my first year of sporadic tractor usage, and look forward to many more (and more frequent seat time)!
   / Tractor rim capstan winch?? #23
Technically speaking,a snatch block is just a block with one side that can be opened so the rope can be placed on the sheave without threading it from the end of the rope. Like this.
Here is a nice page that explains the various methods to achieve mechanical advantage using pulleys.
SUMMERLIFT - Pulley Basics
And a pretty picture....
If you happen to get around any sailors...pronounce it "taycul" and they might buy you a drink.
   / Tractor rim capstan winch?? #24
The snatchblock can be used to change the direction of pull. :D
   / Tractor rim capstan winch?? #25
Thanks, both of you. I knew that the snatch block was essentially a pulley, but that opening feature is the best!
<trundles off to TS or HF or HD or Lowes or something...>
2013 CATERPILLAR 336E L (A58214)
2013 CATERPILLAR...
2013 FREIGHTLINER CASCADIA (A55745)
2013 FREIGHTLINER...
JOHN DEERE 410L BACKHOE (A52706)
JOHN DEERE 410L...
2021 Chevrolet Silverado 2500HD 4x4 Crew Cab Pickup Truck (A56858)
2021 Chevrolet...
NEW Wolverine Skid Steer Auger Drive And Bit (A59000)
NEW Wolverine Skid...
2015 Freightliner Derrick Digger Truck (A55973)
2015 Freightliner...
