Tractor Recommendations - New vs Used
/ Tractor Recommendations - New vs Used #11
Hi MaineBob,
Welcome to TBN--there is a tremendous wealth of experience you will find here--it's great...
If you have the cash & don't need to finance, get yourself a used machine... use varies from the homeowner puttering around the yard to the guy bouncing down log roads dragging tonnage behind... with a private sale you can probably discern what the use has been by the hours, condition of tractor & implements, service records, etc.
I'd have gone used, but needed the financing--and 0% for 36 mos... I am pleased.... maybe buy new! /forums/images/graemlins/grin.gif
If you can find a 2-4 yr old machine that's only lost that off the lot depreciation, you should logically come out ahead overall... a lot of folks crave more & more horsepower, or want to get work done 20% faster... I'll bet there are a few that traded up to 50-70 hp instead of that "little 40-50" that was "slowing them down" /forums/images/graemlins/wink.gif
If you have your heart set on the 4520 though, and can swing it, why not buy what you really want?
Good luck! /forums/images/graemlins/cool.gif
/ Tractor Recommendations - New vs Used #12
</font><font color="blue" class="small">( I'm tempted by a new JD 4520... This may be the only time in my life I can afford new... this may be the last tractor I ever buy. )</font>
I think the answer is right there, I know it would be for me... /forums/images/graemlins/grin.gif
To all ..... Thanks for the advice. Definitely not a consensus on new vs used, but the various comments did help. Right now, I leaning towards new .... mostly because I cannot seem to find anything used with a HST transmission. I'm not 100% convinced a HST is the way to go, but since I'll be doing mostly loader work, it seems like the best option.
I did find a 60-hours used powerreverser JD4520, but the price differential was only a few thousand $$'s. The 0% / 36 financing, establishing a relationship with the dealer, getting it configured the way I want it, and knowing the FULL history of the machine all seem to add up to more than the little savings vs a new machine. If I do go used, I will likely buy a little further south (e.g., PA) where there are more options, and talk my dad into coming up for a visit ... towing a tractor.
Besides the obvious JD vs Kubota (others create challenges with dealer proximity), I need to decide on top-end compact (e.g., L5030 or JD4520) vs low-end utility (e.g., M4900 / JD5105). The challenge with the low end utility tractors is that they do not come in a HST version. HP vs convenience??
Decisions, decisions.
/ Tractor Recommendations - New vs Used #14
60 hours is not very much at all. Barely used I would say.
I'm not expert on tractor trannys but if I didn't have an HST I'd definately get a power reverser / GST type of tranny. Guessing they are similar? clutchless (I mean no human clutch?).
I think you should give that lightly used 4520 a second look if it saves you a few thousand. You can establish a relationship with a local dealer when you get things setup on it - purchasing a few implements, adding a remote or two.
If I had found a year or two old L3400HST, in a private sale, I think I might have jumped on it - for two thousand or so less + no sales tax on top of that (we have a LOT of sales tax up here in Canada).
Also remember even with 0% financing, the best deal can be usually had on cash alone. This is true for cars and true for tractors. Often the manufacturer will kick in a bit of cash incentive. May not be huge but any amount helps.
Good luck with whatever you decide.
Viewz VZ65UHD 65in 4K Security and Signage Monitor (A59231)
Viewz VZ65UHD 65in...
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
PENDING SELLER CONFIRMATIONS (A59906)
PENDING SELLER...
HYDRAULIC THUMB FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2013 Tahoe Q4 Boat with 2013Tracker 18ft S/A Boat Trailer (A59231)
2013 Tahoe Q4 Boat...
2005 CASE 580 SUPER M SERIES 2 BACKHOE (A62129)
2005 CASE 580...
