Tractor rake
/ Tractor rake #1
bennyhill
yanmar 2210b
Has anyone ever welded the forks on a rake? Didn't know if this would be a good thing to do..
They do get loose from time to time, and gets bent.
I just didn't want to lose one or more of the teeth.. I have lost a tooth on the box blade took me hours to find it under the Mud ;,(
/ Tractor rake #2
I'm not sure that is a good idea because
the tines are designed to be replaced if bent or broken
/ Tractor rake #3
Like stated not a good idea, the tines are heat treated and tempered...
To be fair it can be done but the procedure is usually left to certified welders, there is a whole set of preheating, welding with correct filler, temperature and possibly slow cooling or after heat that has to maintained to produce a weld that won't fail or the tine won't fail..
/ Tractor rake #4
Red top is absolutely right. Those are spring steel so they would have to be welded then stress relieved then re-heat treated. Possible but ain't worth the time and effort just buy another one
/ Tractor rake
Had to ask.
Thanks everyone :sneaky:
/ Tractor rake #6
Maybe you should look into attaching them a batter way if there always loose and falling out.
Why are they coming loose?
Landhonor MPF-11-2000G Skid Steer Pallet Forks  (A62679)
Landhonor...
2022 EZ-GO ELITE...
2012 CARGO CRAFT 24' T/A ENCLOSED TRAILER (A65643)
2012 CARGO CRAFT...
CATERPILLAR D8T CRAWLER DOZER (A64279)
CATERPILLAR D8T...
Mini Skid Steer (A60352)
Mini Skid Steer...
ATTENTION PLEASE READ (A64126)
ATTENTION PLEASE...
