Tractor-powered Log Splitter on B7100HST?
   / Tractor-powered Log Splitter on B7100HST? #1
jas67
Platinum Member
Central PA
Kubota B7610 + Kubota G1800-S
   / Tractor-powered Log Splitter on B7100HST? #3
Any comments on using the following on my B7100HST?
Harbor Freight Tools - Quality Tools at the Lowest Prices
It is rated for a max pressure of 2500PSI. The B7100HST relief valve is set for 1500PSI. Will i still be able to split logs? I'd like to avoid having yet another small engine that only gets used once or twice a year.
Thanks,
Jay
I downloaded the owners manual. It has a 4" dia hydraulic cylinder.
If you do the math Pie x radius squared = area of cyl.
3.14 x 4 = 12.56 square inches
then area times pressure = force
12.56 X 1500 = 18840 pounds of force
18840 divided by 2000 = 9.4 tons of splitting power at 1500 psi.
Plenty of power to split most wood.
The small gallons per minute output of the b7100 hydraulics might make the splitter a little slow to run.
   / Tractor-powered Log Splitter on B7100HST? #4
Yeah, just do the simple pi math thingy...sheesh
   / Tractor-powered Log Splitter on B7100HST? #5
I was all set to make a splitter for my B7100 last year. I did the math for power and speed and tried to come up with a decent compromise on the cylinder size. Then I picked up a 6 ton electric splitter for $125. It seems to work fine for my purposes and takes up very little space. I split a load of hickory last fall. The wood pile is a lot tidier now a days.
   / Tractor-powered Log Splitter on B7100HST? #6
running log splitters off old/small tractors is not a good idea. The stroke speed is SO slow that you'll need to be a very patient person.
2007 Case IH 2588 4WD Combine (A50657)
2007 Case IH 2588...
2005 CATERPILLAR 12H MOTOR GRADER (A51406)
2005 CATERPILLAR...
2019 Ford Fusion SEL Sedan (A50324)
2019 Ford Fusion...
2022 Case TR340B Skidloader (RIDE AND DRIVE) (A50774)
2022 Case TR340B...
2011 BMW 5 Series 550I GT Sedan (A50324)
2011 BMW 5 Series...
2019 CATERPILLAR D6 LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
