Tractor power using disc mowers
   / Tractor power using disc mowers #1
pvcman1
bridge lake bc
mccormack international434
Hi,was looking at buying a disc mower untill i found out it recomended a min of a 50hp tractor mine been 43hp.would 7hp make alot of difference?,it would be cutting 4 foot tall grass on flat land.Thanks.:confused:
   / Tractor power using disc mowers #2
A drum mower would work.
   / Tractor power using disc mowers #4
They rate equipment for a reason , it would be good if you could try one out to see . It may mean you would only have to go a little slower then a tractor with more HP. .A dealer might give you some good info. also from their experience with that piece of equipment .
   / Tractor power using disc mowers #5
you can get a 6ft disc mower that should workk on your tractor.now in tall thick grass you may have to cut in low 2 with the rpms at 2000 or a tad higher.
   / Tractor power using disc mowers #6
Starting a disc mower is hard. I use a 9 1/2 foot pull type MoCo and you do notice starting it and any incline makes the tractor work. I mow at 6 mph with a 95 hp tractor.
One more note on disc mowers, I haven't looked at the specs in a while. At one time Deere under the rated HP recommeneded x HP + cab. About once a year the cab takes a hit from rocks, usually from hitting a woodchuck mound hidden in the grass. I know other members here have said that they have even had windows broken.
I wouldn't mow without either a cab, or maybe a sheet of polycarbonate between me and the mower. Possible with a 3 point mounted machine any rocks would end up going either forward to the tire would block them. I would still not want to run one with an open tractor.
Here is another thread on disc mowers and the very 1st post brings up that the some OEM's want a cab tractor.
http://www.tractorbynet.com/forums/attachments/75746-questions-disk-mowers.html
Yes I have a complete curtain on the front of the machine and all guards in place. Rocks still find their way out of the machine.
   / Tractor power using disc mowers #7
   / Tractor power using disc mowers #8
My rule of thumb is 7 pto horsepower for each head on flat ground. It takes a bit to get one going, even my 100 pto tractor balks a bit on startup (blows a little smoke). Always a cab tractor. an open station is an invitation to get hit by tocks, wood or whatever that the discs throw forward.
I actually have 2 mowers, a sickle bar conditioner and a disc bine. I use the sickle on fields that I'm not sure of whats under the hay (like a new customer). I never run the disc machine on new fields.
Typically, I can mow twice as fast with a disc compared to a sickle and plugging in tall, damp forage isn't an issue, however, the sickle produces a better close cut on 2nd and 3rd cuts versus the disc.
If fuel is an issue, always run a sickle. Disc machines suck fuel, much like round balers versus small square bailers.
Finally, if in doubt about any poly twine left in a field (from missed bales, run a sickle. Poly twine is a quick death for the upper seals on a disc machine.
   / Tractor power using disc mowers #9
Find a disk mower rated for 40 PTO, 5 disk gear drive or 6 disk shaft drive.
I would want full power for 4 foot high grass. I run 5 disk gear drive on 42 PTO HP, I have to drop a gear in the stuff that is thick and taller than the 14.9-28 rear tires... Tractor plays with it otherwise and I am sure it would run 6 disk gear drive in most of my cutting.
HAMM H11 PADFOOT ROLLER (A58214)
HAMM H11 PADFOOT...
2010 Doyle 32ft Tender Trailer - Kubota Diesel - Stainless Steel Augers - Recently Refurbished (A56438)
2010 Doyle 32ft...
2015 TROXELL 130BBL STEEL (A58214)
2015 TROXELL...
UNUSED I/A F10 TILT 10' HYD TILT BOX SCRAPER (A57192)
UNUSED I/A F10...
2004 FORD F-350 XL DUALLY CREW CAB FLATBED TRUCK (A59823)
2004 FORD F-350 XL...
NEW Woods 6ft Finish Mower (A56438)
NEW Woods 6ft...
