SPYDERLK
Super Star Member
- Joined
- Feb 28, 2006
- Messages
- 12,635
- Location
- VA
- Tractor
- JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
As the formula shows, slow rotating engines must produce more torque to achieve equal HP. There is no advantage to the slightly slower turning engine. The two just need different gear ratios to apply their hp effectively. The diesel advantage is that its torque curve is flatter. It has more tractable power delivery and demands less of the operator/transmission. It "wins" because it is easier to use.When comparing equally matched horsepower ratings of engines diesels win in torque every time.
Example. HP=torque x rpm/5252. Torque=hp/(rpm/5252).
A 22hp gasser that gets peak hp at 3600 rpm has 32 ft/lbs of torque. A 22 hp diesel that is rated at 3200 rpm has 36 ft/lbs of torque. Yes, a very small differance but still a differance.
larry
