Tractor Performance: diesel vs gas
/ Tractor Performance: diesel vs gas #141
From a quick google search...
Carburetor, new, for Ford: 501, 601, 701, (1958-1962); 2000, (1962 to 1964) with 134 CID gas engine. Replaces Marvel Schebler carb. part #TSX765 and Ford #B8NN9510A. (Manufactured to duplicate original Marvel Schebler design. Parts are interchangeable with original Ford or Marvel carburetors.)
Price: $231.77
Complete carburetor repair kit. Contains all parts necessary for major carburetor overhaul. For Ford tractors: NAA (1953-54), 600 & 700, (1955-57), with 134 CID gas engine. Repairs Marvel Schebler carb. #TSX428 & TSX580 and Ford #EAE9510C & EAE9510D.
Price: $42.93
Who knew such a simple carb now gets so much money?
jb
The carb prices there are high.. you can get them for well under 200$.. the rebuild kit.. for the good one.. is about right on.
soundguy
/ Tractor Performance: diesel vs gas #142
Don't forget the 50% fewer gallons of fuel needed in the diesel over the thousands of hours. That's where you get your economic gain.
I was actually only addressing the mechanical issue. I'm on record as preferring a diesel.
/ Tractor Performance: diesel vs gas #143
Okey Dokey.
Say, this topic is about played out. Let's start up (again) about HST vs gear. Or is it time for 2wd vs 4wd? I forget where we are in the lively discussion rotation...
jb
/ Tractor Performance: diesel vs gas #144
Hey, my BIL put diesel in his boat before going fishing last week. Believe it or not, with about half gas and half diesel he managed to keep it running with the choke pulled all the way out. Does that count as "both"; gas and diesel? :D
/ Tractor Performance: diesel vs gas #145
How about TVO!.. Bet if he had a proper vaporising carb.. it woulda ran better!
soundguy
/ Tractor Performance: diesel vs gas #146
Who the heck wears out a carb????
I know of 5 old gassers, NONE of them don't have the original carb. I know on the Olivers that I have run, they have thousands and thousands of hours on the original carb. They might get a carb kit every 25 to 30 years.
To me the advantages of diesel are thus:
1. more power
2. better torque
3. motors last longer at high loads
To me the advantages of gas are thus:
1. better in motors that are started and stopped a lot with short run times.
2. motors that sit for very long periods of time
3. Cold weather starting
/ Tractor Performance: diesel vs gas #147
No. It counts as a multi-fuel engine. :)
/ Tractor Performance: diesel vs gas #148
Again.. you guys are stiring the pot by posting these blatant bits of fact here in this highly opinionated discussion ;)
( I've also got carbs with brass rebuild tags on them fromthe 50's and 60's... go figure! )
soundguy
/ Tractor Performance: diesel vs gas #149
Okey Dokey.
jb
You are trying to stir up trouble, sir. The real question is R4s vs R1s vs turfs!!! :mad:
:p:):D
/ Tractor Performance: diesel vs gas #150
this may be a stupid question, I know there is off road diesel but is there off road gas?
/ Tractor Performance: diesel vs gas #151
In some of the areas I am familiar with there is.:D:D
/ Tractor Performance: diesel vs gas #155
Okey Dokey.
jb
Gear!
/ Tractor Performance: diesel vs gas #156
This is sort of a good question. I had a 1956 CJ3B a few years back. It ran but never that well, always rich. My uncle had it in the 70's, then my dad, then me about 1989. I had cleaned, soaked, kitted the carb way back in the 80's when I re-ringed it. About mid 80's Dad was using it at the beach house and wanted it running better. I converted it to 12v (left the 6v starter), so that helped the starting. He bought a new carb, whuch I found out later was an older rebuild. When I got the jeep I went through it again. I found a new manufactored carb from a jeep quy out on the west coast. Can't recall the name, wanna say Walbro but I think it was something else. Anyway, once I put it on the old F-head ran perfect. It'd idle all day, no more loading up. Cost was about $150 or so.
So what makes them wear out, if this one wore out. perhaps it was the wrong carb on this one. Carbs are not made from the strongest materials.
/ Tractor Performance: diesel vs gas #157
Might have been oversized jets too.. I've opened thm up and seen where peple drille dout jets ot OS them.. etc..
soundguy
/ Tractor Performance: diesel vs gas #158
Avgas and marina gas. Trouble is, you pay more, not less.
If you have a farm number, you can get a form from the state and get reimbursed for the road tax on gasoline in Indiana. But you better have that farm number up to date and all legal like or they'll nail your hide to the wall. :eek:
/ Tractor Performance: diesel vs gas #159
Over at Farmallcub those guys did some intensive research on the little IH carb. many had rich issues. It was discovered there was about 4 different jets in a variety of carbs and most were too large and most of the rest were oversized through abuse or on purpose. They have since documented the correct specs for the carb.
/ Tractor Performance: diesel vs gas #160
I definitely like diesels: can do most jobs with less hp than gas because of big torque of the diesel....[snip]
In a 3,000# car, for instance, a 100 hp diesel is great; whereas, you need about a 125-140 hp gas engine one for the same performance.
Ralph
The torque issue that causes a diesel to compete favorably with a gas engine of equal horse power is that there is more area under the torque curve. This means that the torque of a diesel engine is flatter, maintaining a high level over a broader rpm range. This, in turn, means that the diesel produces more hp than the gasoline engine at all parts of the rpm range except at the rated rpm of each engine. At that point only, does the gasoline engine produce the same HP as the diesel. This is a demonstration of tractability - the diesel HP is easier to use. It absolutely cannot do more than a gasser of same HP if the gas engine can be maintained at an appropriate rpm. This is almost impossible with a gear transmission, but becomes more likely when comparing the use of automatic transmissions on each, and can be identical with both transmitting their identical peak HP thru HSTs where "gearing" can be varied infinitely. A gasoline engine having greater horsepower will always outperform a lesser HP diesel if the transmission/operator combination is sensitive enuf to use the narrower range where the gas engine produces its peak --not very difficult with an HST.
As far as economy and durability: Due to its unrestricted breathing and very high compression the diesel has an efficiency advantage that further compliments the energypergallon superiority of the diesel oil. The fact that diesels are better lubricated because they are burning oil improves their endurance under hard work.
larry
1968 MTTI Car Hauler Trailer Trailer (A62613)
1968 MTTI Car...
AR500 Coyote Target (A65640)
AR500 Coyote...
2022 Seppi MINIFORST CL 175 Skid Steer Forestry Mulcher (A65640)
2022 Seppi...
2001 International School Bus (A64194)
2001 International...
(5) Steel Wheels (A65640)
(5) Steel Wheels...
12ft. 24 Gauge R Panels (A65640)
12ft. 24 Gauge R...
