Tractor not warming up
/ Tractor not warming up #21
I would check and verify that the gauge is correct before disassembling anything. If you have an temperature gun point it at the top radiator hose near the engine and compare it to the gauge reading.
Another thing to consider, IS it full of coolant. An engine that has air trapped in the system or is low on coolant will sometimes show low coolant temp. (this is due to the bulb on the sensor not being submerged in coolant.) The gauge will read hot air, but not accurately.
As others have stated, being a used tractor, you never know what somebody else may have done, but it is never a good idea to leave the regulator out of the cooling system.
Engines need a regulator in the cooling system to keep the engine components up to a desirable temperature to help aid piston ring seal, keep the engine oil temp high enough to burn off condensation, etc..
In extreme cases, the absense of a regulator can actually cause piston seizure.
/ Tractor not warming up #22
Did some semi heavy work today w my new to me tractor and noticed again that it won't get out of the yellow in the engine temp gauge, had the tractor running at least an hour at around 1500rpm(540 pto is right around 2100rpm) I know the gauge works, cause when I start her up, she's well below. Any ideas?
Unlike gas engines which, at a given ambient temperature, run at relatively constant peak gas temperatures versus rpm (that's determined by fuel/air ratio and compression ratio and throttle position), diesels run at variable peak gas temperatures versus rpm (big variations in fuel air ratio and no throttling of the intake airflow). In general, the slower the diesel engine runs, the lower the peak gas temperature in the cylinder. That's why you'll have a hard time warming it up by just idling it. You need to increase the rpms and the work output by putting it under load.Running your engine at 1500 rpm when it is rated at probably near 2500 for max power, tells me you are running it at the low end of the peak gas temperatures. That's the physics of the engine side of this discussion.
Before you do anything, work your machine a little harder (1800-1900 rpm) and see if the temperature indication increases. If it doesn't, check the thermostat.
Remove it from the housing just below where the upper hose comes out of the cylinder head. Heat some water to whatever temperature your thermostat is rated at (it's usually marked on the thermostat), and put the thermostat into that water and see if it opens. If it does, thermostat is good. If it doesn't, replace the thermostat.) if you want to forego this experiment, just buy a new thermostat and replace it.
Re install a good thermostat in your engine and work the engine to bring it up to temperature. Let the engine cool, for an hour and then CAREFULLY REMOVE THE RADIATOR CAP and restart the engine. Look into the top of the radiator and see if water is entering the top of the radiator from the top hose. If it is, measure the temperature and note the position on the temperature gauge on the tractor. (If it isn't entering the radiator, run the engine with the cap off till it does then measure the temperature.) You'll now have a calibration point between the thermometer and the gauge. Compare that temperature to the temperature you noted on the thermostat.
If you are at the correct measured temperature relative to the thermostats rating, and the gauge reads low, then it's possible your temperature sensor's output is incorrect but I doubt there is any data to tell you where on the temperature gauge you should be except "in the green band".
My guess is that you are running the engine at too low a power and it's ot warming up at the ambient temperature you're working it at. That's why you're seeing what you're seeing. However, it is also possible though not as probable you could also have a bad thermostat or a bad sensor.
/ Tractor not warming up #23
there is a big hose running from the top of your radiator to the front of your engine. This hose connects to a metal fitting that is then bolted to the engine. Remove those two or three bolts, that hose and fitting will pull off, exposing your thermostat.
Drain the coolant before doing the above work.:thumbsup:
Have you placed your hand on the top of the rad to check for heat. If it's comfortable it's too cold.
/ Tractor not warming up #24
There are no shutters on the 2002 freightliner I'm running now, nor were there shutters on the 2009 Prostar I was running a year and a half ago, or the other 'half dozen' Internationals, nor the Volvos I drove over the past ten years.
You probably have a clutch fan and other methods of control on the newer trucks
/ Tractor not warming up #25
I think radiator shutters disappeared when the air-to-air intercoolers arrived on the scene, at least that was the case with the Freightliners and one Kenworth that I owned. Don't want to block airflow to the intercooler.
/ Tractor not warming up #26
My guess is that you are running the engine at too low a power and it's ot warming up at the ambient temperature you're working it at. That's why you're seeing what you're seeing. However, it is also psossible though not a sprobable you could also have a bad thermostat or a bad sensor.
Hey i agree with everything you said about not lugging a deisel and it needs to operate at say 90% throttle to be efficient and have all its power.
But i think the OP said that he was running at the PTO speed which equated to 1500 RPMS. I know nothing about his tractor but that seems way to low to me, but again i am just pointing to what he said.
Saying this if he turns 1900rpms he will be overspinning his bushhog.
/ Tractor not warming up #27
He said PTO speed was at 2100 rpm.
/ Tractor not warming up #29
I had opposite problem, my overheat light came on almost with start up. Checked everything like others have recomended, all ok, so changed the temp bulb.:)
/ Tractor not warming up #30
The wrong t-stat may be installed, some have a built å�*n leak that is ok for a car but too much for a cut. Lots of things to look at.
/ Tractor not warming up #31
All very good advice, but I would try the simple fix first.
My tractor engine only got lukewarm in cold weather even when working it hard. I never gave it much thought until I got a cab and a heater. A piece of cardboard with about a 5" round hole in the middle now covers the radiator in the winter months, and my heater puts out great heat. Engine temp varies from 170-210F depending on how much snow I'm moving. I watch the gauge, when it gets up to 210F I go a little easier for a bit. I need to strip down to a t-shirt at that point anyway.
The cardboard comes out in the spring and the engine runs at about 180F most of the time.
/ Tractor not warming up #32
There's about 100 reasons why a engine will overheat, but only 1 why it won't heat up - the thermostat... ;)
/ Tractor not warming up #33
Hey Beeferman,
thats a great anecdote,i'll have to remember that:D.
This whole thing reminds me that between myself and my brother
we've had three Kubotas,all bought new and none of them will heat up
(according to the gauge) in the winter.I thought it was the gauges being wrong till I realized in the summer they run right about half way on the gauge.
I guess i'll have to be checkin out MY thermostat.Very possible it could be stuck open,or maybe just part way.Seems strange though that all three did it though.Thats why i figured the factory gauges were junk.I'll have to check it out.While i'm at it,i might as well put a decent aftermarket gauge on it too.
digger2
/ Tractor not warming up #35
I don't get why people would expect the gauge to read the same in the cold of winter on a little tractor engine. I have to be working mine really hard for over an hour before it gets to read fully warm, when it's like this outside. I thought that was a sign that the gauge worked good.
/ Tractor not warming up #36
Put a snowblower on it and get into some deep snow.:thumbsup:
It'll warm up.:D
