I'm not familiar with your tractor, but as a general rule, when looking at your engine and radiator, there is a big hose running from the top of your radiator to the front of your engine. This hose connects to a metal fitting that is then bolted to the engine. Remove those two or three bolts, that hose and fitting will pull off, exposing your thermostat. Pay attention to how it goes in there. You can just pull it out. This is going to spill coolant, so have a drip pan ready to catch fluids. If you leave it open for any amount of time, put clean rags in thermostat hole and the hose. When looking at the thermostat, there is the flat round outer diameter, and a flat round disc with a spring in the center. At room temp. the disc should be flat against the outside ring. if it's not, replace it. If it is, put in a pan on the stove in warm water. Heat the water while monitoring the water temp. with a thermometer, and it should start opening up around 160*F to 180*F as Gerard stated. If this works, your good. If it is wide open long before that, it needs replaced. If it doesn't open at all it also needs replaced. I hope this helps and is easy to get to. I'll try to check back often so don't be afraid to ask questions. If there is anybody familiar with this tractor, please chime in if I missed anything. Good luck!!
