Oil & Fuel Tractor not starting after changing fluids
/ Tractor not starting after changing fluids #1
smithdenny
spencer, tn
kioti dx55
Today I changed the fluids and filters on a DK5510 for the first time. I had warmed up the engine beforehand. Now, the unit will not crank, the starter will not engage. Battery is charged. Seems to act as if there may be a safety switch that is preventing if from starting. All indicator lights on dash seem to be operational, but simply nothing when the switch is in the cranking position. What am I overlooking? Thanks in advance for any ideas.
/ Tractor not starting after changing fluids #2
Check the position of all levers, seat switch, PTO, and the treadle that moves the tractor.
Thanks for your suggestions HillStreet. Those are some of the items I suspected might be the problem. It may have been simply the battery was not charged as well as I thought. I connected a charger to the battery to make sure it was charged, tried the engine after the input was down to about 1 amp still with no response. However I left the charger on overnight and this morning it started right up. Still not sure it wasn't a safety switch somewhere, or embarrassingly I can not read a volt meter!
Update: I just remembered before starting the tractor this morning I did manually depress the positioning switch on the clutch pedal. This tractor definitely will not start without depressing the clutch so I am going with that as the possible cause instead of admitting low battery possibility! <grin>
/ Tractor not starting after changing fluids #5
You got it!!! My CK30 wouldn't crank if the clutch isn't pushed in. It's a safety feature so that you don't run over yourself(if standing beside tractor to start it). Dutchy
/ Tractor not starting after changing fluids #6
We all (probably) did this at some time. The variable is how long it took to figure it out.
/ Tractor not starting after changing fluids #7
Thank you for posting what it was, unlike many post problem but not fix!
2014 DRAGON  130BBL VACUUM TRAILER (A65643)
2014 DRAGON...
John Deere 5420 Tractor with Quicke Loader (A64047)
John Deere 5420...
Bobcat Skidsteer (A60352)
Bobcat Skidsteer...
2001 Peterbilt 330 4,000 Gallon Water Truck (A64194)
2001 Peterbilt 330...
Woodsman 332 T/A Towable Brush Chipper (A64194)
Woodsman 332 T/A...
New/Unused Mini Quick Attach Pallet Forks (A65583)
New/Unused Mini...
