tractor newbie, new '64 Case 530 owner
   / tractor newbie, new '64 Case 530 owner #1
bmicad
Case 530
New to tractors in general and the Case 530 in particular. I am planning on fixing up the brakes first. There seems to be alot of brake shoes for the 530 on ebay. Anything in particular I should be on the lookout for?
   / tractor newbie, new '64 Case 530 owner #2
Welcome to TBN. :)
   / tractor newbie, new '64 Case 530 owner #3
Many of the older tractors used dry brakes and it was most important to keep teh mechanisms clean and working freely then the discs themselves.
   / tractor newbie, new '64 Case 530 owner #4
More than likely, the seals are leaking. If the discs look to be decent yet, an old Case collector showed me how to take a propane torch, and burn the oil out of them. Just run the torch over the discs in a circular motion, and get them pretty warm. It will literally boil the oil out of them. I was afraid of them coming un-bonded, but he said he has done many of them, and they haven't. Use your own judgement on this. I did, and it worked well... Just finish cleaning them up with brake cleaner, and maybe rough the surface with finer sandpaper. I now use my Roloc medium discs to do this.
The seals will probably run you $15.00-$17.00 ea., depending on where you get them.
Do one side at a time.
You will probably need to drain the tranny oil down some, or the oil will come out the bottom brake housing bolt hole, when you remove that bolt.
To keep from damaging the new seal when installing... Wrap electrical tape around the cleaned splined shaft. Start the tape on the inward side, on the flat area where the splines end, and just before where the seal rides on the shaft. Coat the tape with oil, and slide the seal on. With the tape wrapped this way, the seal will be riding on smooth ridges, not against them. Leave a little extra on the outward end to get ahold of. When done, pull the end of the tape, and it will spiral itself right off of there.
There will also be 4 LARGE Phillips head machine screws, holding on the plate on the backside of the brake disc assembly. You wil need to remove this to get to the seal, if they are bad... I replaced them with hex/allen head screws of the same size and shape. Much easier to torque back in, although it is only like 15 ft. lbs.
There are also some shims behind that plate. Just make sure you don't damage, or lose them.
Not a bad job, just takes a while....
2019 VOLVO L70H WHEEL LOADER (A52706)
2019 VOLVO L70H...
Gas Pump Artwork (A55758)
Gas Pump Artwork...
2009 CATERPILLAR D4K XL CRAWLER DOZER (A52706)
2009 CATERPILLAR...
2008 Ford Fusion SE Sedan (A54815)
2008 Ford Fusion...
greenworks (A53421)
greenworks (A53421)
Simplex Packaged Pump Set (A47477)
Simplex Packaged...
