Tractor Maintenance
   / Tractor Maintenance #1
freddiepez
Aurora, OH
New Holland 30HP
I have a NH TC 30. Bought it used but in great shape with only 600 hours. Time to change the oil. Can I use "motor oil", or do I need to use a special oil for diesel engines?
   / Tractor Maintenance #2
Welcome to TBN.
Ideally you would use a high quality synthetic or semi-synthetic DIESEL oil rated to the tractor's specs for grade.
Mobil one diesel, Amsoil diesel, etc.
   / Tractor Maintenance #3
I've been using Rotella-T Triple Protection in my TC40. Shell Rotella® Products - Shell Rotella
Never tried the synthetics such as the Rotella T5 or T6, but they should be as good or better.
Rotella T is available everywhere, including Walmart.
   / Tractor Maintenance #4
You need C rated oil, not sure what API rating there up to now CG?? But yes its a diesel rated oil, use what ever rated oil the manual says like 15w-40 or 10-40 or what ever. MOst use Mobile delvac, dello, rotella T, or some syn oil.
Diesel oil is different, it is formulated to hold ash and soot in it in suspension.
   / Tractor Maintenance #5
Oh if you post In the oil and lube forum its a better place for it.
UNUSED Black Outdoor Patio Fabric Screen (A53117)
UNUSED Black...
2022 FREIGHTLINER CASCADIA SLEEPER (A54607)
2022 FREIGHTLINER...
2017 CHALLENGER MT465E TRACTOR (A51406)
2017 CHALLENGER...
John Deere Gator XUV560S4 4x4 Utility Cart (A50324)
John Deere Gator...
UNUSED LANDHONOR TP2-13-08D HYD TREE PULLER (A54757)
UNUSED LANDHONOR...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54607)
2019 FREIGHTLINER...
