Oil & Fuel Tractor looses power
/ Tractor looses power #1
Murfster3
Jones,MI
Mahindra
Mahindra 4010. Driving tractor after 4 minutes starts to die, changed paper fuel filter. Still dies I let idle about 20min it dies. I don稚 see another fuel filter. Called local service they said to change 2nd filter I can稚 find it???
/ Tractor looses power #2
From the filter you already changed their is two gas lines- one from the tank and one going toward the engine. That fuel line headed to the engine should go through a second filter. I’m not 100% on that model but the typical would be a spin on filter that looks like an oil filter.
Edit: a quick google search didn’t turn up a second filter. If it doesn’t have a second filter check to make sure the tank isn’t plugged where the fuel line attaches (somewhat common) and make sure a fuel line didn’t rot internally causing a blockage (somewhat less common). I’d also call the dealer back and verify it has a second filter.....maybe ask the parts person to produce a part number and cost- their book should have a schematic.
/ Tractor looses power #3
Where do you live, exactly? Goshen is, like, 15 minutes away from me.
Happy to help and "Buster's" probably has the filter.
I live in Jones, Michigan which is 30 minutes north of goshen
/ Tractor looses power #8
One thing to try that is free, assuming that you've already checked the fuel for contamination, if fuel tank venting. Simply start it with the fuel cap off, or at least very loose, to test.
/ Tractor looses power #9
sounds like a fuel injector problem to me or shut off solenoid
2016 Peterbilt 579 Automatic High Top Sleeper (69") (A62613)
2016 Peterbilt 579...
2024 DEVELON DL250-7 WHEEL LOADER (A63276)
2024 DEVELON...
2018 Kenworth T880 Quad Dump (A62613)
2018 Kenworth T880...
John Deere 568 Mega Wide Plus (A60462)
John Deere 568...
2019 GMC SIERRA HD 3500 (A63569)
2019 GMC SIERRA HD...
2005 John Deere 7320 (A60462)
2005 John Deere...
