Tractor loader repair
/ Tractor loader repair #1
Rio_Grande
Platinum Member
I was using my FEL today with the pallet fork on it. I was using the tilt to pick things up (nasty habit learned from skid steer) and busted the hinge point right off of my loader where the bucket attaches. I looked it ove anr it appears that the way it was designed the bushing was just welded into the end of the arm with no other support. I am looking for an Idea on the fix for this. Any suggestions would be appriciated. I do think I know why this happened. I boutght a QA for the tractor that had 3 top mount points. I think I mounted them too low causing the tilt rams to be pulling back hard on the bottom point. It tore off so It was likely the rams pulling on it.
I need to fix this lickty split so any suggestions will be concidered.
/ Tractor loader repair #2
You could weld another bushing on the end, then grab some 1/8" flat stock & weld beyond where you welded the bushing on, covering your first weld. Now instead of 2 welds on each side (top & bottom), you have 6.
/ Tractor loader repair #3
RIO, what brand/model of loader is this? Can you post a photo?
It is a freeman loader. I will try to get a photo up.
Jeff
I tried to take some pix tonight but the camera was to cold to work. I will get some after work tomorow. I did find another signifigant crack on the other side. Probably because I continued to use it after it broke.
Well I couldnt get pix while it was broken, but I hav attached pix of the repaired arms. I found out what the problem was. The ATI quick attach I bought was hitting the arm whan I was dumping. That is why when I pointed the forks straight down to push myself out it broke the eyelet out.
So of course I Fixed it back the way it was before I figured out why it had done what it did, so I had to rework it. By that time the wind was blowing and I got a bunch of booger welds. Sometimes the mig is not the right machine for the job.
Anyway as soon as it dries up a bit I will try it out.
Pix:
attachment.php
attachment.php
CHECO GREASE UNIT (A68842)
CHECO GREASE UNIT...
PORTA POTTY (A67714)
2015 Peterbilt 320 Roll-Off Truck (A66736)
2015 Peterbilt 320...
2022 CATERPILLAR 299D3 XE SKID STEER (A65056)
2022 CATERPILLAR...
2014 Ram Pro Master 2500 Cargo Van (A66736)
2014 Ram Pro...
2022 LEVEL BEST GB100 108" HYD GRADER BLADE (A65053)
2022 LEVEL BEST...
