Tractor light bar
/ Tractor light bar #11
Looking at the number in the box, this looks to be the box that is being used.
PVC Junction Box 4" x 4" x 2" RJB44
I believe you can get the other pieces that hold the wire at any of the box stores, lowes/home depot/menards. You can find a similar electrical box also as I was looking at the pvc type boxes yesterday since I had read this post.
/ Tractor light bar #12
That looks like a box made by CANTEX. The gasket constantly falls out of the lid if you remove it. A Carlon box has the gasket captured in the lid, and is better than CANTEX's open cell foam type.
/ Tractor light bar #13
Thanks for this. I'm going to use your plan on my '03 B7800. What should I adjust if I can't do the alternator kit now but plan to later? Assuming I would only run 2 55w lights at a time instead of 4 to prevent battery drain. Noob here...
/ Tractor light bar #14
/ Tractor light bar #15
Go with LEDs. I put two of these on my tractor roll bar, one pointing forward and one back. 72 watts total draw which is 6 amps at 12 volts. Suprisingly good quality for the price.
Amazon.com: Nilight 7" 36w Spot LED Work Light Off Road LED Light Bar 12v Driving Lights Super Bright for Jeep Cabin Boat SUV Truck Car ATVs,2 Years Warranty: Automotive
2008 Ford F-350 4x4 Ext. Cab Knapheide Service Truck (A59230)
2008 Ford F-350...
KUBOTA L3901D TRACTOR (A59823)
KUBOTA L3901D...
2021 KENWORTH T680 TANDEM AXLE SLEEPER (A59575)
2021 KENWORTH T680...
2004 EAGER BEAVER 50GSL/3 DETACH TRAILER (A52707)
2004 EAGER BEAVER...
2022 FORD F-250 STV CREW CAB TRUCK (A59823)
2022 FORD F-250...
2014 Bayliner 180 Boat with 2004 Venture 24ft T/A Boat Trailer (A59231)
2014 Bayliner 180...
