Tractor Lesson: Hauling & hydro
   / Tractor Lesson: Hauling & hydro #1
theboman
Grayson, KY
Kubota B7500 HST
My tractor lesson I learned today.
When trailering a tractor such as a B7500. When you have the tractor loaded put it in low 4 wheel drive and set the parking brake. This locks all the brakes on all 4 wheels. In two wheel drive you only lock the rear tires by setting the parking brake.
The BX mowers that folks burn up the casters (anti scalp rollers) on the decks, it's not so much of a problem with the decks design but the owners are setting these too close to the ground, they should not be rolling along the ground unless there's a high spot the BX has a suspended deck not a floating deck. They replace these often.
One of the guys at the dealership didn't realize the BX don't have a tach. I told him about the tiny tach and this board. He then went on to tell me they tell folks to run the throttle wide open when using the PTO because too low RPMs cause nothing but problems and that tractors are designed to be worked and not lugged. You can't over rev the engines from the factory (unless you've messed with the governor/carb on the machine).
When checking the hydro fluid make sure the FEL is down compelely, the lines on a B7500 can hold several gallons of hydro fluid.
   / Tractor Lesson: Hauling & hydro #2
I keep the anti scalp rollers on my BX set a lot higher than the book says and have had no problems with them so far. My yard is mostly just an old pasture that I mow. Definitly not very smooth and if I set them at the recommened level they tend to want to turn all the time.
I thought they would have made the rollers a little more robust though,at least something that you could grease. Dave...
   / Tractor Lesson: Hauling & hydro #3
I do the same thing (running the rollers high) and have seen no real difference in cut. I set them for a 3" cut and then set it at 3.5" to mow. I wish they made a ball bearing roller, but I guess cost is an issue there. I took all of them apart and lubed them once after getting into some mud with the deck on, and they are already dry again. I guess I'll pull them apart again......................
DaveL
   / Tractor Lesson: Hauling & hydro #4
"When checking the hydro fluid make sure the FEL is down compelely, the lines on a B7500 can hold several gallons of hydro fluid."
Whether the loader is up or down, the lines will always contain fluid, they do not drain out with the loader up. The only difference in volume is that when you have in this example the loader down, that area of the cylinder that is filled with fluid when the loader is up is diminshed some by the hydraulic componets, namely the hydraulic ram. I see no fluid level difference on my tractor with all hydraulics extended or retracted. It might make a difference on yours however. Rat
   / Tractor Lesson: Hauling & hydro #5
I agree, Rat. There is a slight difference in the quantity of oil in the cylinders (no difference in the quantity in the lines and hoses), but the difference is not great enough to be of any concern.
   / Tractor Lesson: Hauling & hydro #6
You might want to try graphite instead of oil. I think it would stay longer and wouldn't collect dust. Just a suggestion.
   / Tractor Lesson: Hauling & hydro #7
Yea,I agree with using graphite.If you need proof just get some on your fingers,it doesn't like to come off.
VOLVO L45G WHEEL LOADER (A51242)
VOLVO L45G WHEEL...
2016 Nissan NV200 Cargo Van (A50323)
2016 Nissan NV200...
KOMATSU PC130-8 EXCAVATOR (A50854)
KOMATSU PC130-8...
1269 (A50490)
1269 (A50490)
2019 Ford Fusion SEL Sedan (A50324)
2019 Ford Fusion...
2022 FREIGHTLINER CASCADIA SLEEPER (A51222)
2022 FREIGHTLINER...
