Tractor hydraulics leaking down
   / Tractor hydraulics leaking down #1
hlyautey
Eatonton, GA
1949 8N
If the 3 point leaks down after you shut the engine off would the problem be in the pump or the lift cylinder?
   / Tractor hydraulics leaking down #2
Unless it leaks all the way down in an hour or so it isn't really a problem in most cases.
Mine leaks down because the valve leaks a bit....takes over 24 hrs with the counterweights (ballast) to go 1/2 way down. I normally drop my load anyway, serves as an anchor.
   / Tractor hydraulics leaking down #3
My 8n drops in a few seconds whenever I push in the clutch, so I have to shift into neutral and get off the clutch to keep the lift up.
   / Tractor hydraulics leaking down #5
I think you surely have a lift cylinder problem. On the 8N, the pump is in the hydraulic reservoir under the seat and only works when the clutch is released. I would say you have an 80-90% chance of it being the lift cylinder seals. If you plan to do the work yourself, get an I&T Manual available at Tractor Supply or online at many sites including the Amazon.com link posted.
I have the manual and have been reading it. I understand that after you do something once you become an expert. I looking here for experts. In a few months maybe I can act like lone just a little. I think my little red belly was really abused by the previous owner, judging by the weld repairs and damaged parts. I suspect he was using a too large finishing mower behind it. I've gone through the brakes, looking to rebuild the steering box next, then this lift issue. Thanks for your input, and I agree with your assessment.
2015 Kenworth T270 24ft Morgan Box Truck (A51692)
2015 Kenworth T270...
2025 IR UNUSED Cleanout Bucket (A53117)
2025 IR UNUSED...
2015 Eager Beaver 15HBB-PT T/A Flatbed Equipment Trailer (A50322)
2015 Eager Beaver...
2013 Nissan Pathfinder SUV (A51694)
2013 Nissan...
Brand New 5 gallon buckets (A53117)
Brand New 5 gallon...
2015 John Deere Z950M 70in Zero Turn Mower (A51691)
2015 John Deere...
