Tractor hydraulic/tranny fluid
   / Tractor hydraulic/tranny fluid #1
djt
Western MA
LB1914
Hi,
Getting ready to change the fluids and filters (50 hour service) and was looking for hydraulic fluid brand suggestions.
Thanks, Dave
   / Tractor hydraulic/tranny fluid #2
I used oil from autozone, in red 5 gallon pails. Key is to use tractor hydraulic fluid, any good all purpose should do. The manual should also spell out what should be used.
   / Tractor hydraulic/tranny fluid #3
Even the costco in our are has it, napa too. You'll need about 7 gallons and a BIG drain pan.
   / Tractor hydraulic/tranny fluid #4
I use Chevron 1000 THF in my CK30, unfortunately my local jobber only has it in 5 gal. buckets.
   / Tractor hydraulic/tranny fluid #5
Any fluid that meets specs should do fine.
The first time I changed mine I used the premium TSC fluid. There was nothing wrong with it but prior to warming up for a good length of time, it was noisy in sub-freezing temps, as was the original fluid.
I changed to Kubota Super UDT last year and my CK20H was noticeably quieter upon startup in cold temps this past winter.
   / Tractor hydraulic/tranny fluid #6
djt said:
Hi,
Thanks, Dave
WalMart carry's SuperTech Tractor fluid (Hydraulic & HST) in 2 gallon plastic cans. Forget the two gallon plastic containers.........just buy a five gallon pail.
Lucky for me I had a big tub to dump fluid from tractor. It was a 1 1/2" too tall with my bachhoe extension frame so I parked tractor tires on four pieces of 2 X 8 on the flat. Pay particular attention to magnet on drain plug for Hydraulic fluid resovoir. Mine was loaded with shavings confirming the need to change out fluid on new systems at 50 hours.
Ford Garage was glad to take the used fluid. They use it for heating by burning it in the winter.
rimshot
   / Tractor hydraulic/tranny fluid #7
rimshot
Mine was loaded too, I also had a ton of it on the magnets on the filter bolt. I used a 16 gal feed tub for my fluid changes. Had to partially empty it to do all the fluids on my 45. Do not be surprised if you have some difficulty getting your sockets on the plugs the first time, seems like you have to break the paint to get them on.
My dealer uses the sams club hst fluid at his shop, works for me too ( and pretty cheap).
   / Tractor hydraulic/tranny fluid #8
I'm racking my brain in my recent 50 hours inspection for my new CK20 in trying to figure what you mean by filter bolts. Hope I didn't miss something. What in the world are filter bolts? Are you talking about the two additional drain plugs for the hydraulic reservoir?
rimshot
Thanks for the info. I noticed walmart carried supertech and Rotella. was wondering if anyone was using either.
   / Tractor hydraulic/tranny fluid #10
I use the rotella, most guys here seem to recommend. Seems like good diesel oil.
2025 New/Unused LandHonor Heavy Duty Plate Compactor (A51573)
2025 New/Unused...
2017 Ram 4500 Bucket Truck (A53472)
2017 Ram 4500...
2012 International DuraStar 4400 Service Truck with Crane, VIN # 1HTMKAAN2CH076971 (A51572)
2012 International...
2004 KENWORTH DIGGER TRUCK (A52472)
2004 KENWORTH...
JOHN DEERE Q 850 M LOT NUMBER 226 (A53084)
JOHN DEERE Q 850 M...
2016 Case 821F Articulated Wheel Loader (A51691)
2016 Case 821F...
