Tractor front end geometry???
/ Tractor front end geometry??? #21
This sounds like a problem in hydrostatic steering. Some slipping is acceptable and normal but yours sounds like it has a problem.
The free play in the wheel is just under 1/8 of a turn. There is nothing loose on the front end.
With the hydro steering there needs to be some fluid/pressure before it works normally. I fired up the tractor and turned the wheel 180 deg slowly at idle and the wheels barely budged. A couple quick wiggles after that it became
responsive. This is normal...so I'm told.
I've driven other tractors and they are about the same with the free play. Appearently this is the norm. Its been this way and worked fine for a hundred years. Why change it now?
2025 Swict 84in Bucket Skid Steer Attachment (A66734)
2025 Swict 84in...
2009 CHEVROLET IMPALA (A66091)
2009 CHEVROLET...
2013 Wacker Neuson LTN6 (A64911)
2013 Wacker Neuson...
23.1-26 Tires - Set of 2 (A68134)
23.1-26 Tires -...
AGT QA Pallet Forks (A64912)
AGT QA Pallet...
2013 HAULMARK ENCLOSED UTILITY TRAILER (A67714)
2013 HAULMARK...
