tractor for cordwood?
   / tractor for cordwood? #1
wilson-nate
Hi
im looking at buying a tractor probably a kubota b series. my main purpose would be for moveing cord wood into my dump trailer and moving logs. does anyone know what a good size machine would be for this? how a bucket loader would do picking up the wood out of a pile (not stacked). any comments will be helpfull.
Thanks
   / tractor for cordwood? #2
If you are going to the expense of buying the tractor to move wood like that you would probably be tickled to have the front hydraulic grapple on the bucket. I have loaded wood into the bucket on my tractor and then driven it to the wood pile to stack. I am the type that likes to minimize how many times I have to move that wood..
   / tractor for cordwood? #3
You will need a good sized tractor to be able to drive in the bucket into a wood pile. Something like 35 HP with a lot of counter weight and filled tires. Like the others say a grapple is absolutely necessary. Tires will make a big difference also for the traction needed to get the tractor into the pile. If on asphalt or concrete probably R4's, if on soft ground like dirt, gravel, or sand R1's would be the first choice.
Chris
   / tractor for cordwood? #4
Best "tractor" for cordwood, John Deere 648-GIII, 150HP, 24.5-32 16ply tires, 100in easco swing boom grapple, 7 foot blade, heat and a/c. Oh,I am a 3rd generation farmer/logger. This IS the tractor for cordwood. "Thats a four foot across bug kill spruce tree in the grapple".
any idea if a bobcat would do any better?
   / tractor for cordwood? #6
Just my two cents is you would have more versatility with a tractor if you have any other sort of work to do around your property. Say mowing or post holes. Things like that. Bobcats are great machines. If you were just doing firewood then that might make sense.. Not sure of the lifting capacity of the B series Kubota you are looking at.
   / tractor for cordwood? #7
I have also used the farms NH7740 mfwd tractor with a woods 255 loader when dealn with cut up cord wood. The neighbor does allright with his 43 horse montana tractor,dont know the model number, when he has a pile to deal with. Rather shuffle around wood with the 790. Works good, just takes a little longer. The rock/debris bucket on the 790 works good to keep dirt, bark and other stuffs out of the piles while holding more wood than the standard bucket also. The 790 is in the B series size range of tractor you are lookn at. A little bigger tractor would move more, faster. JD790 or B series kubota is more manuverable in the small spaces than the bigger tractors.
   / tractor for cordwood? #8
Hi
Thanks
Let us know how much wood (cords)you are talking about. If you are talking 2 cords a year, most anything will help out although it would be difficult to justify the many thousands of dollars. If you are talking hundreds of cords commercial business it is a different answer.
   / tractor for cordwood? #9
I have used my BX-23 to move it around it does work better with a tooth bar I can tell you that much.
I cant get a lot in my bucket but it sure is better than picking it up by hand.
tom
the pile is probably about 20-25 cord. we usually have 2 piles and will probably be expanding from there if we have something to save our backs with
2016 Nissan Titan XD SL 4x4 Pickup Truck (A51692)
2016 Nissan Titan...
2017 Case SV185 Compact Wheel Loader Skid Steer (A51691)
2017 Case SV185...
JOHN DEERE XUV590M LOT NUMBER 27 (A53084)
JOHN DEERE XUV590M...
2018 John Deere HPX615E Gator 4x4 Utility Cart (A51691)
2018 John Deere...
2008 Cadillac Escalade ESV 4x4 SUV (A51694)
2008 Cadillac...
Frontier 60" Grapple (A50123)
Frontier 60"...
