Tractor FEL Crane *Update*
/ Tractor FEL Crane *Update* #81
People like all animals are hard wired differently. Some here may not have followed their father/mother out of the house each morning to make a living on the farm by making do with what they had to do with.
Thats a great point.
Phil doesn't fit though because while he was standing in Home Depot buying this stuff he could have purchased the "rated for overhead lifting" pieces for a few more dollars.
At worse I expect is he will drop one and have to rebuild it.
I expect Phil will succeed in his task without any problems. But the worst case scenario is someone getting seriously injured from something snapping.
Phil is going into this with both eyes open
I don't get it. If there is an easy route for safety, making the less-safe decision is somehow justified under any circumstances? I guess thats why we have to have so many lawyers, warning labels, and regulations. Because people want to do whatever they want instead of whats right.
/ Tractor FEL Crane *Update* #82
and the other thing is if this works out good ,will he try to lift somthing heavier that might not work out as well.
/ Tractor FEL Crane *Update* #83
wldrbob, exactly. And just look at how many people already think there is nothing wrong with doing this even while admitting to knowing people who died while doing similarly poorly-thoughout things.
/ Tractor FEL Crane *Update* #84
Just in case you missed it. These are the trusses Phil will be lifting one at a time with the crane.
/ Tractor FEL Crane *Update* #85
It is quite normal to have a strong desire to flirt with death. It is also quite common for one man to project his fears on another. How does one safely race in a pack of cars going 200 MPH?
Yesterday even I flirted with death. For the first time I got all four wheels of the backhoe off the ground at the same time. I felt like I was going to roll over when I went to max height on one outrigger before lowering the other side but I held on tight. Thankfully I spotted step ladder first so I had an exit plan.
/ Tractor FEL Crane *Update* #86
arrabill- Guess we're going to have to, agree to disagree on this matter. I'm goin' ta bed, go eat some tofu and bean sprouts! Sleep well! ~Scotty
/ Tractor FEL Crane *Update* #87
SAFER barriers, full face helmets, HANS devices, inertia fuel cut-off switches, CAD designed roll cages, roof flaps, stand-by safety crews and doctors, and they just switched away from the wing because it seems it was causing cars to go airborne. NOWHERE in that did they just decide safety was unimportant just because racing is inherently dangerous.
arrabill- Guess we're going to have to, agreed to disagree on this matter. I'm goin' ta bed, go eat some tofu and bean sprouts! Sleep well! ~Scotty
I'll sleep well knowing I was able to argue my point without having to resort to sixth grade insults.
/ Tractor FEL Crane *Update* #88
Some of you guys should realize that he going to get the job done, no matter what it takes, and he has already thought this thing out. He says it will work, some of you doubt it. Safety is fine, but how many of you follow all the safety standards. You all cut corners, and you know it. What are you going to say, if and when he completes his project, Oh, he was just lucky, sooner or later it will break, OK, OK, call the safety police, etc. I would guess that the boom will work as planned, and he will get the job done with no or very little help from others. Remember, he does have a remote control for the winch, and he doesn't have to stand under anything.
Even if something should break, just about all inventions had failures before a successful conclusion.
/ Tractor FEL Crane *Update* #89
JJ thanks for saying it so well for so many of us.
/ Tractor FEL Crane *Update* #90
Thank you JJ! ~Scotty (Bunkering Down here for more incoming!!)
/ Tractor FEL Crane *Update* #91
well he thought part of it out . if he realy thought about it he wouldnt have posted till he was finished the job lol
/ Tractor FEL Crane *Update* #92
wldrbob-If he's like me, you use this site as a resource. You have an idea, run it by this forum, adjust as recommended, and go forth! I thought this "Idea Exchange" was what this board was here for. ~Scotty
/ Tractor FEL Crane *Update* #93
Yankee ingenuity is a not always grasped by the masses but they tend call upon it when others are trying to kill them.
The point is not where Phil spent years getting an engineering degree and called in an OSHA inspector that makes his project so exceptional. The project shows us the man behind the project. He exposed himself to the words of those who were not interested in being part of the solution. He took and acted on the words of those who wanted to be part of the solution.
If I am ever in a bad accident and trapped it would be my prayer that one of the "Phil's" of this world would show up and try his best with what was at hand to help.
Some people are thinkers/doer's and others are not.
Rather than reply here, I started a new thread on this topic, showing the performance of the crane at work. I did this in an attempt to move away from the "bickering" flavor that seems to have hijacked this thread, and, hopefully, set a more reality based discourse in the conversation.
See FEL Tractor Crane *Proof of Performance*
/ Tractor FEL Crane *Update* #96
I for one like the solution to the challenge. There are many what if this what if that's about any project and they do have points. BUT. The one job you did with the crane is finished or near so. That means you were aware of the shortcomings of the design and were careful not to get in trouble. GOOD JOB and thanks for posting the pictures!!!
/ Tractor FEL Crane *Update* #97
I see people here getting unnecessarily defensive on what is offered as an open discussion topic. Most of the challenging comments were offered as valid concerns. I too would question just about very aspect of the design. However, in spite of being an engineer, I will occasionally push the limit and take risks in what I'm doing simply because it's the easiest way out at the time.
What it all amounts to is... you can cross a deep gorge using a bridge or a fallen tree. The choice is yours.
/ Tractor FEL Crane *Update* #98
wldrbob-............pill duly ingested, as requested!:licking:
/ Tractor FEL Crane *Update* #99
Those who play Russian roulette seldom blow their brains out at the first attempt...
/ Tractor FEL Crane *Update* #100
Lots of valid points on both sides of this.
Yes, it did go OK.
Yes, it COULD HAVE turned out all wrong.
Yes, I do find myself able to argue it from both sides at the same time (-:
Yes, I did nearly roll over yesterday trying to do something "marginal" on a side slope.
Yes, I did NOT have my seat belt on - and MAYBE my rapid clambering to the high side got the balance back.
Not saying it did, but getting a couple of hundred pounds to that side probably didn't make things any worse.
Oh yeah, I acknowledge the action/reaction of my movement clockwise about the roll center vs the tractor's counterclockwise tipping.
...and I have driven home WAY too drunk WAY too many times, fortunately I never hurt anyone physically or financially as a result.
and I never got caught.
NOT statistical evidence that I could/should ever do it again - and I will not, not even ONCE.
