Tractor Electrical ?
/ Tractor Electrical ? #1
mcd176
Wheeling, WV
Kubota M6800HD / Kubota B2150
I have installed a 6 position fuse panel rated for 180 AMPS in my tractor to run the following:
1. Front Work Lights 55W
2. Rear Work Lights 55W
3. 3 Speed blower for heater
4. Radio
5. Dome Light
6. Empty
My question is this, what size wire should I run from my battery to the fuse block, it is around 12' from the battery to the fuse block, should I use 8 or 10 gauge?
-Mike
/ Tractor Electrical ? #2
Without knowing how much power the blower/radio/dome light actually draw, it can be a tough call. To size the wire to the 180A of the fuse panel would take about 1/0 AWG over twelve feet. I'm sure that's overkill for the actual loads you're putting on. What size fuses do you have in each slot?
If you have a 5A fuse in each slot, you'll tap out at 30A and can use the 8AWG.
-rus-
/ Tractor Electrical ? #3
if he's needing 180a.. he needs a nice beefy alt too!
I agree on the 8awg.. 4 if he had some sustained loads like a inverter.
soundguy
I do not need 180A, I was just telling you all that it is a 6 pos, fuse block rated for up to 180 Amps.
Thanks for the advice guys, I will go with the 8 Ga.
-Mike
/ Tractor Electrical ? #5
if i understand what you said correctly, you are going to run an 8 ga wire from the battery to the fuse panel with a run of 12 ft. the 8 ga wire needs some kind of fusible device as close to the battery as possible. if not fused thats a sure fire starter if it ever shorts to ground ,which is not an unlikely scenario on a tractor.
/ Tractor Electrical ? #6
  • BambiCam-Wire ANSI D R1 11x17.pdf
Thanks guys, I wasn't thinking about the inline fuse untill you mentioned it, that could have been real bad!!
Mjn,
Excellent drawing, I will have to steal some ideas from it, thanks again for your help.
-Mike
/ Tractor Electrical ? #9
Whatever size you use, just make sure that it is the flexible type, not the normal 7 strand building wire...and fuse it
/ Tractor Electrical ? #10
JJ,
Do you have any other info, if someone wanted to purchase one?
/ Tractor Electrical ? #11
Factory fuse is an inline 50 amp on 8 gage wire located at the starter feeds into the cab.
You can get a similar fuse at auto zone or ORilies as a FLF-50 (fusible link).. KennyV
MAGNUM LIGHT TOWER (A65643)
MAGNUM LIGHT TOWER...
2014 BRENNER 210 BBL CRUDE TRAILER W/ PUMP (A65643)
2014 BRENNER 210...
INDUSTRIAS AMERICA 2426 - 10' OFFSET DISC HARROW (A64277)
INDUSTRIAS AMERICA...
2012 Ford E-350 16ft. Box Truck (A64556)
2012 Ford E-350...
Landhonor Quick Attach Log Grapple (A66285)
Landhonor Quick...
2006 JOHN DEERE 310G BACKHOE (A65053)
2006 JOHN DEERE...
