Tractor cutting out while on full throttle
   / Tractor cutting out while on full throttle #1
mad_planter
Hi All
I have a Ford 250c, roughly equivalent to a 4500 series ford. I was using it to spread gravel on the driveway and when it was running at more than full throttle it would start to cut out, I would throttle it down to a idle before it died completely, it would idle fine, and when I throttled it back up it would run fine again. It did this several times, and the last time it died completely and wouldn't start. Anybody have suggestions on what it might be or how I can diagnose it? Any help would be greatly appreciated.
   / Tractor cutting out while on full throttle #2
Fuel restriction. Check tank vent, tank outlet, fuel line, filter.
   / Tractor cutting out while on full throttle #3
Ditto, though I don't understand how it can be running "...more than full throttle...".
*************Update**************
I haven't had the chance to run through the fuel system yet looking for obstructions. I had a few minutes of spare time and just looked it over and Discovered the hard line from the filter to the injector pump was finger loose, and the return line was a little loose as well. Would sucking air cause this symptom? I tightened everything up and started it and it still cuts out when at full throttle, not all the time though. Could there still be air in the filter that is getting sucked in from the line being loose?
Still plan on running the system looking for foreign material, I only had a few minutes to spare so far and wanted to mention the loose line. I don't think it would be appreciated if I had left the house smelling like diesel.:laughing:
   / Tractor cutting out while on full throttle #6
3 things are required for combustion. It takes very little deviation from design to cause you issues. You are either starved for fuel, oxygen, or the ignition source.
UNUSED FUTURE FT36C STAND ON SKID STEER (A52706)
UNUSED FUTURE...
CASE INTERNATIONAL 5140 TRACTOR (A52707)
CASE INTERNATIONAL...
2010 GMC Seirra 1500 4x4 Crew Cab Pickup Truck (A55973)
2010 GMC Seirra...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A55973)
2018 Ford F-150...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2016 Peterbilt 389 T/A Wet Kit Sleeper Cab Truck Tractor (A55973)
2016 Peterbilt 389...
