Tractor Cab Build
/ Tractor Cab Build
Do you have any heat in the cab? If yes, is it electric or something off the engine?
Heat was an essential part of the build.
I used an automotive heater core (had one from a car project that never got used) in a simple DIY box with computer fan (extra strong one) and fan controller, mounted up on the ceiling. It blows down onto the windshield.
It's fed antifreeze from the water pump bypass. Easy to do. I doubt anything electric would really warm things up.
The system is shown and described in the video. Starts at slide 80. Have a look if you're planning something.
/ Tractor Cab Build
I decided I might as well post this.
Links to Materials
(not a complete list)
4-3/4" Weld-on Steel Bullet Hinges w/ Brass Bushing/Grease Zerk
RV Teardrop Trailer Camper Front Locking Door L Handle Latch Kit
WEXCO 4R1.12.L85D 1.5” WINDSHIELD WIPER MOTOR 12V ADJUSTABLE AMERICAN BOSCH 12V
Wexco 200715 14"-18" Wiper Arm
DROK 180038 Digital Voltage 10-170 ℉ Temperature Monitor Tester Multimeter Car Motorcycle Battery Voltmeter Thermometer Detector
MICTUNING LED Illuminated Automotive Blade Fuse Holder Box 6-Circuit Fuse Block with Cover
STV Motorsports Laser Blue Rocker Switch INTERIOR LIGHTS 20A 12V On/Off LED Lights
ONLINE LED STORE 4-Slot Rocker Switch Panel [Industry Standard Fit] [Heavy Duty] [Expandable Design] [Professional Look] Automotive Mount Toggle Switch Housing
T-H Marine LED-51800-DP LED Slim Line Utility Strip Lights, 4" - Clear
Nilight Led Light Bar 2PCS 18w 4" Flood Driving Fog Light Off Road Lights Boat Lights driving lights Led Work Light SUV Jeep Lamp,2 years Warranty
Wang-Data Black Split Loom Braided Cable Sleeve 1/2 inch X 20ft (1/2" X 20')
Wang-Data PET Black Split Loom Braided Cable Sleeve 1/4 inch X 20ft (1/4" X 20')
Ultra Strong 12cm DC12V Cooling fan. 200CFM
RioRand™ Upgraded 6V-90V 15A DC Motor Pump Speed Controller
BETOOLL Golf Cart Wide Panoramic Rear View Mirror Ez Go, Club Car, Yamaha
XFasten Adhesive Hook and Loop, Black, 1-Inch x 10-Foot Industrial Grade and Wear and Tear Resistant
Country Brook Design | Black Sew on Hook and Loop (1 inch, 10 yards)
Trim-Lok Trim Seal with Top Bulb – PVC Plastic Trim with EPDM Rubber Bulb Seal – Fits 1/8” Edge, 3/8” Bulb Seal Diameter, 25’ Length
KUBOTA L BX B series TRACTOR VINYL DECAL STICKER -WHITE w/ black - 1 12" Decal
KUBOTA TRACTOR VINYL DECAL STICKER - WHITE with BLACK - 9" Wide - SET OF 2
Michigan Seat Lowback Lawn/Garden Tractor Seat - Black, Model# V-250*
Other Items Purchased Locally - No Links
1 1/2” square tubing (16g) - 80’ - $127 (close to 20' left over)
1” square tubing (16g) - 60’ - $62
16g sheet metal - 48” x 120” (less than half used) - $125
3/8” metal rod - $ not much
1/4” acrylic sheet - 4’ x 8’ - $200
self locking window gasket - 50’ - $108
3 layer automotive glass and gasket installed by glass shop - $600
/ Tractor Cab Build #23
That is a masterpiece!!!! I personally have the CNC plasma that would make the whole CAB build a lot easier, but, I do not dare to do it! You nailed it!
/ Tractor Cab Build #24
ideehoan, got a question for you regarding the pantograph wiper arms.
I know that the main blade fits over the splined wiper shaft but how do you attach the bracket for the second arm. It seems to fit rather loosely on the threaded shaft of the wiper motor. Is this bracket supposed to be held in place with a nut or just hang there.
Thanks, oh i got the same arm and motor that you used.
/ Tractor Cab Build #25
Absolutely incredible!!! You have some amazing skills and I love that you shared them with your grandson. Subscribed!
/ Tractor Cab Build
My apologies, I'm not getting notifications of posts and have not been here for a while.
I imagine you figured out the second arm attaches to a bracket which slides onto the main mounting stud and is secured by the stud nut. It has a hole for a bolt / screw to prevent spinning but I found I did not need it.
Hilbilly and Polemidis - thanks.
Sometimes timing is a sweet thing. We set a record for most snow ever in February. I was smiling a lot.
Not to toot my own horn here, but just for anyone planning a build, I have so far not found anything I would like to change. Hard to believe. Eventually I'm sure there will be and I'll post updates.
/ Tractor Cab Build
Just thinking about this. If you've got the CNC, I can't imagine you don't have some skills. Likely more than me. It's really just the will to do it.
I never drew anything out, just mounted a piece of square tube to the roll bar and started adding on.
Of all the things I've built, this was most satisfying because of how useful it is.
/ Tractor Cab Build #28
Great job on the cab. CNC plasma would have made a few cuts in the sheet easier, but for the most part, porta band, stationary band and angle grinder with cutting wheel prob does better with the materials utilized in the build. Built a cab for a Case 446 a few years ago. Cost of laminated glass and Lexan was an eye opener.
/ Tractor Cab Build
Thanks.
Yes the glass was the biggest expense by far.
You're right of course about tools. My thought was just that anyone with a CNC has some knowledge and skills.
/ Tractor Cab Build #30
Really nice build and hats off to your video. Excellent job.
CAT D5G LGP DOZER (A58214)
CAT D5G LGP DOZER...
Year: 2016 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55853)
Year: 2016 Make...
2018 Freightliner M2 106 Cab and Chassis Truck (A59230)
2018 Freightliner...
ALLMETAL MOBILE PRESSURE WASHER (A58214)
ALLMETAL MOBILE...
4021 (A59228)
4021 (A59228)
PALLET OF 11 BARBED WIRE ROLLS (A58214)
PALLET OF 11...
