Tractor bogged down then shut off
/ Tractor bogged down then shut off #1
CaseVol
Case JX70
I was mowing hay with a Case JX 70 tractor with a New Idea 5408 disc mower. As I was mowing I ran into a wire cage that I did not see and it got caught up in the mower and before I could disengage the PTO the tractor shut off. I then disengaged the PTO, started the tractor back up and parked the tractor.
Is it likely that I have damaged my tractor and if so how can I determine whether the tractor has been damaged. This tractor is brand new (only 90 hrs) and is still under warranty. If it is damaged I wonder if the warranty would even cover this.
/ Tractor bogged down then shut off #2
You should b ok you just over loaded the motor. Is the 5408 ok, thats a good mower.
/ Tractor bogged down then shut off #3
no i have wrapped up barb wire in my disc mower alot and it hasn't hurt my tractor one bit
/ Tractor bogged down then shut off #4
Not likely to have hurt the tractor. Most mowers have a shear bolt or slip clutch. I would give it a visual inspection and try the mower out. The one thing you may want to do is check the adjustment of the slip clutch if it has one. It might be set a little tight. If you hurt the tractor it would be in the pto and they are built robust.
Thanks for the replies. Don't know about the mower yet. I'll look into tomorrow. I would say that your right about the slip clutch needing adjustment. After what happen I thought I would call it a day. Wasn't in the mood to possible discover any problems. Also needed to go to the house and change underwear (haha). Goin be fun getting all that wire out of the mower.
2023 JOHN DEERE 450P LGP CRAWLER DOZER (A64279)
2023 JOHN DEERE...
2015 Global M3 Street Sweeper (A64556)
2015 Global M3...
2016 FREIGHTLINER CASCADIA ROAD TRACTOR (A65054)
2016 FREIGHTLINER...
2015 Peterbilt 337 Galbreath CH8000 Container Handler Truck (A64194)
2015 Peterbilt 337...
1997 Duraco Dura Patcher 81DJ Towable Asphalt Patcher (A64194)
1997 Duraco Dura...
2015 Ford Explorer SUV (A64557)
2015 Ford Explorer...
