Tractor backhoe - homemade
   / Tractor backhoe - homemade
That's exactly what I want to avoid. This is the replacement for the telescope. It will be a compilation of previous experience with rk 525 and some new ideas
   / Tractor backhoe - homemade #972
Triple boom also gives you a greater working angle. With a teledipper, the dipper/boom hinge is limiting your work angle. Also, you can work with just boom lift and dipper cylinders, with an extended teledipper the ratio between dipper and boom is so off that you have to work with 3 functions at the same time.
I agree. Besides that, with this setting I will get alot more force on the second half of the boom and the dipper. When you extend the telescope there is an enormus loss of force at the end because of the length of the boom. This way if I need to lift something heavy I can put my first part straight up an use only second half of the boom with the dipper. I spent some time thinking about this and for me it has all the advantages over telescope...
Ofcourse. This can't be done without her. Who's gonna weld it together? ;)
   / Tractor backhoe - homemade #976
Do you have contact at work to make a build this nice happen for less than a million dollars? How did the cost of the last build compare to a commercial built version? Sorry if I missed the answer. I haven’t read all 1000 post.
   / Tractor backhoe - homemade #977
Is she the reason those welds look so fantastic? I've been welding my whole life, and those are some nice welds.
   / Tractor backhoe - homemade #978
You're missing out if you didn't at least follow the pictures. Amazing work.
   / Tractor backhoe - homemade #979
I watched his last backhoe build. I just found this thread. I’ll try to look through it later. Edit I’m not as far behind as I thought. I followed his last build. This one is just getting started right?
4570man there was no commercial build backhoe of this size and properties to buy. At least not here. There are some backhoes built in Italy but these are toys compared to rk 525. They have half the reach and power...so I decided to build one myself and I will never regret that it's a great experience ;)
Buffalo Model #3 Horizontal Angle Iron Roll (A59213)
Buffalo Model #3...
(2) CUTTLER HAMMER 200 AMP DISCONNECT (A52708)
(2) CUTTLER HAMMER...
2019 CAT TL1055D (A58216)
2019 CAT TL1055D...
2023 John Deere 333G for Parts (A56436)
2023 John Deere...
PALLET OF PLASTIC SHEETING & ENTRANCE DOOR (A58374)
PALLET OF PLASTIC...
2025 Yakta YXR970 Zero Turn Mower (A57453)
2025 Yakta YXR970...
