Grading Tractor as Bulldozer/ Kubota Front Blade
   / Tractor as Bulldozer/ Kubota Front Blade #11
THKS for the compliments.
I've only used it twice. Job 1 was to till a steep bank and push the dirt UP the hill to fill the gulleys and plant grass. It did great with the loosened soil. It's 6ft wide, so I could see what was going on by looking at the ends of the blade. It worked well back dragging also.
Second time I used it on snow clearing driveways. It was marginal at best. I was worried about hooking a landscape rock or something, so I was going slow. And it needed to be taller to push much snow. I suppose if we got more snow, I could extend the top and put a rubber lip on the bottom.............. What I use to move the little snow we get is to bolt a 4ft 2x12 on the bottom of the FEL so as not to scratch the driveways and just use the FEL.
I've considered mounting a rear blade on the front, but really don't have a need. And if you designed it to pivot, you'd have a lot of weight way out front. And it would EASIER to swing the FEL into stuff! (I'm good at that with the FEL alone!)
The thing that would scare me about a pivoting blade out front is when you hook something solid, it would put some real stress on your FEL.
If you guys want to build a front blade, you might want to incorporate something I just did to my grill guard: I welded in a receiver hitch to carry a homemade weight box. If you did that, along with some other mounting hardware up higher for lifting, etc, you might have something that could handle the blade, and handle the stress of hitting a solid object without tearing up your tractor. See the pic of what I did.
Ron
Thanks ron, good ideas and thoughts - I appreciate it.
Perhaps to avoid the pivot issue - which I agree is a real possiblity - one could use sheer pins in the pivot? Not something that had occurred to me before, but I will now make it part of my plans. Maybe want to incorporate them on the 3 pt, as well. Hmm. Thanks.
How do you bolt the 2x12 to the fel? Another great idea.
   / Tractor as Bulldozer/ Kubota Front Blade #13
My 5030 was outfitted with hoses from the rear remotes to the 853 loader for us with the included 6' Bobcat snow blade. I have't had a chance to use it yet (even for snow), but had wondered about using it for grading dirt or light bulldozing work, but all this talk out FEL arms bending has me concerned. Should I be? If not, this could be a solution for you as well.
   / Tractor as Bulldozer/ Kubota Front Blade #14
Charles, I just bolt the 2x12 under the bottom of the bucket, using 3/8" bolts. I suck the heads into the wood. I have the 2x12 in front of the cutting edge by about 4". then I run the front edge of the wood on the concrete. Sure, it doesn't last too long, but we don't get much snow either.
ron
Thats more or less what I'm thinking of. I don't think straight ahead forces would be an issue - think of digging with the loader - but as Ron mentioned, angled force might be an issue. Probably can be avoided by going very slow and avoiding shock loads.
ron
Ah, I see. I wondered if you were mounting it perpendicular, like the blade. Seems like a good wear edge, and easier than the horse mats that have been suggested before. Probably equally hard as the blade on my gravel though...
   / Tractor as Bulldozer/ Kubota Front Blade #17
I use this setup for pushing LIGHT snow off of my concrete driveway. I wouldn't want to be ramming snow plow piles with it, but it works great for fresh snow. I "fixed" it to the angle I have to push my drive off. When the bottom 2X8 flakes out, I reverse it, then change it. Very fast and cheap.
   / Tractor as Bulldozer/ Kubota Front Blade #18
ccsial said:
.....You should not damage anything unless you do a running start.....
I can only envision all sorts of humorous situations with this comment!!!! :)
   / Tractor as Bulldozer/ Kubota Front Blade #19
It looks like it is frame-mounted, definitely not on loader arms.
Does anyone know if that is a six-way blade or only four-way ?
If it is only 4-way, a 4-n-1 bucket can do everything the blade can do, and a whole lot more.
   / Tractor as Bulldozer/ Kubota Front Blade #20
According to Kubota documentation, it's subframe mounted, 4-way (up/down/right/left) and requires the 4-position loader valve.
2019 VOLVO VNL64T860 TANDEM AXLE SLEEPER (A58018)
2019 VOLVO...
2018 DODGE RAM 2500 (A58214)
2018 DODGE RAM...
Toro MBTX-2500 Concrete Buggy (A54865)
Toro MBTX-2500...
2019 CAT TL1055D (A58214)
2019 CAT TL1055D...
2007 Pierce Dash Pumper Fire Truck (A55973)
2007 Pierce Dash...
2008 Ford F-450 Crew Cab Utility Flatbed Truck (A55973)
2008 Ford F-450...
