Tractor and Slopes
   / Tractor and Slopes #1
Billrog
Veteran Member
Armstrong, British Columbia
Kioti 2610, 580 SuperM Case Backhoe
Since joining I've seen a few comments on slopes so today I decide to check a few of the slopes I drive on nearly a daily bases. There is one I have to have something in the front bucket to keep the front wheels on the ground but it's been raining so I never checked it out to see the max. slope the tractor will climb.A couple are my driveway and a few of trails that I use there are approx. 5 miles of trails 70% are just slight grade to med. so this is only a small sample.
Took this pic. so you could see it's actually a trail.
The trails in this area I cleaned up to use from horse logging around 1945.
When working on these hill sides there's a good chance you won't get a second chance if your careless & you should get to know your tractor very well before tackling steep slopes. In some of the open areas I'm able to log without trails.
   / Tractor and Slopes #2
Wow, those are some serious slopes! Be careful. That looks like a perfect place for a Ventrac or Steiner.
   / Tractor and Slopes #3
A digital level! I was expecting a protractor and a plumb bob.
   / Tractor and Slopes #4
That's a interesting thing to do. Lets you see where you fit in. I like your % angle meter. I just have a clinometer on my compass. Works like a plump bob against an angle gauge. It is only 4" long so not to accurate maybe the way I just hold it up and sight along the slope. I never thought of just putting it down on the floor boards...DUH.
You have some steep ground there.
gg
   / Tractor and Slopes #5
When it comes to slopes I can relate to degrees better than percent of grade.
Here is a chart that helps visualize the slope.
Here is my wife's Toolcat with the 7' brush hog on the front, on a 50% side slope.
Note the body lean compared to the tops of the tires.
   / Tractor and Slopes #6
If you have a smart phone, there is an app,,
   / Tractor and Slopes #7
I don't understand the display of 25 degrees? The red pointer is on 15 degrees and that looks right.
   / Tractor and Slopes #8
I don't understand the display of 25 degrees? The red pointer is on 15 degrees and that looks right. <img src="http://www.tractorbynet.com/forums/files/owning-operating/445755-tractor-slopes-degrees-jpg"/>
It's hard to tell from the crumby picture, but the display number is percent, the red pointer is referencing degrees.
   / Tractor and Slopes #9
Here is better pic.
   / Tractor and Slopes #10
Ok. :thumbsup:
2012 John Deere 7280R MFWD Tractor (A52128)
2012 John Deere...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A52128)
Kubota 24in Quick...
2022 JOHN DEERE 450K LGP CRAWLER DOZER (A51242)
2022 JOHN DEERE...
20' Sea Container Mobile Hospital (A50774)
20' Sea Container...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
