Tractor and Excavator OR Tractor with backhoe...
   / Tractor and Excavator OR Tractor with backhoe...
20 20,
I'm sure I would use it more than I think I would - I've found that to be the case the the tractor already, especially the grapple rake. I use it more than the front bucket by far.
At this point I'm planning on a 4520 or similar, and if my backhoe sells I'll likely get the backhoe to fit the tractor I get - but with the plan of renting a mini-ex if I need one for a few projects and potentially purchasing a used machine in a few years if the projects pile up.
One of my challenges (that I know a few here can identify with) is where most of the work gets done is an hour from where I live, so I can't just work on a few projects in the evening like I used to when I lived up near there.
Thank you all for your thoughts - I greatly appreciate it and it has indeed helped me solidify my plans.
   / Tractor and Excavator OR Tractor with backhoe... #22
4520 with home built landplane
Steve,
I'm diggin' your homebuilt landplane... Is there a thread about that build?
Thanks,
David
   / Tractor and Excavator OR Tractor with backhoe... #23
This is a good thread. My plan is to keep my tractor (L4400,) but trade in the Back hoe, and sub-frame (BH 90.) I am real hot for the KX 121. Thanks to this thread, I feel much more confident in what I want to do. I almost considered going with the M59, But I would rather have a dedicated tractor, for loader, and three point work, and a 5 ton Mini ex for digging, logging ex-cetera.
   / Tractor and Excavator OR Tractor with backhoe... #24
These sections seem to be the deciding factors in my opinion
I have use for a backhoe still, but need to be able to get in to some tighter spots, and over some softer areas where my 9 ton 2wd machine just isn't going to go, either size wise or without making a royal mess... and potentially needing a friend with a dozer to pull me out!...
What gives me pause is I'm used to a backhoe with 8k pounds of breakout force... not 2k.... Stumps will undoubtably take longer, but it will be rare it's a big stump so I'm not that concerned. ...
Property wise it's 1+ mile of road plus several miles of ski / snowmobile trails, 200+ acres (mostly woods, but 5+ acres of field with another 10 of beaver swamp (or my own personal mosquito breeding ground as I like to call it)) in the Adirondacks up upstate NY. Lots of rocks, some ledge, hills, etc....
I'd say you're looking for a excavator, with the wide "flotation" tracks for traversing boggy areas. And you need something with enough power to break things out. Yeah, it's not going to move fast; but that's why you preposition equipment before a job.
   / Tractor and Excavator OR Tractor with backhoe... #25
For productivity, if you have the $$$ and the work, go for the mini-ex and loader.
   / Tractor and Excavator OR Tractor with backhoe... #26
Both would definitely be the most productive. Both would definitely cost the most. If you can afford it I would see it as a no brainier but you could get by with a TLB.
   / Tractor and Excavator OR Tractor with backhoe... #27
I entertained myself (and drove my wife crazy) with this debate about 10 years ago... Ended up with 2 different TLB's and lot's of hours renting different excavators and/or dozers.
Clearing land, building roads and parking areas, building pads and building/barn construction.
I've discovered that during the first 5-6 years having a backhoe and renting an excavator was a primary activity.
During the past 2-3 years my backhoe (JD 110TLB) has been sitting on the ground while the tractor has been used most often as a loader-utility machine.
We're now considering buying more land. It's currently all forest covered ground.
I'm gonna buy an excavator and resell it when I've got most of the work done - logging and clearing. Don't know if I'll sell the 110 or not.
Best of luck with your decision.
AKfish
   / Tractor and Excavator OR Tractor with backhoe... #28
Just adding my two cents long after you've likely made a decision. I love the Kubota mini-ex's however I did not go with a tractor and an ex for the following reasons:
- Maintenance on two machines
- The BH92 is more than ample for the work I do on my property and would argue it's enough for the majority of individuals
- Driving an ex on 89 acres is not fun and takes a while to get to where the work needs to be done
- Not enough storage area for two machines (one double garage only for car and tractor)
So those were my reasons. Like I say, mini-ex's are great machines and have great breakout force but it didn't make sense for me. Your reasons are different and it sounds like you're comfortable having two machines easily.
Having 12 miles of trails around the property getting somewhere in a reasonable amount of time is nice - and if I keep those "trails" rather than "roads" for the most part I think a BH on the tractors should do fine for my small projects. Larger ones I can rent for a week and take care of a few projects at a time - and if it seems like they'll keep appearing, perhaps I'll look in to a used one and sell the BH at that point. I do like the idea of less machines to maintain.
If my backhoe doesn't sell I'll trade the tractor in and not get the hoe for it, at least initially. I won't be able to get to some areas, but the "necessary" work get still get done. I'm really only considering selling it to reduce the amount of equipment to maintain, and that it doesn't get used much, and we all know how sitting is just about the worst you can do for a machine.
   / Tractor and Excavator OR Tractor with backhoe... #30
One comment about more machines equals more maintenance, this is true, however if one machine does have down time it still leaves another machine to carry on {just a thought}. I can also say it was great having a mini ex to pull the engine on my dozer, to replace the clutch{made that job easy}. I have had many machines through out the yrs and I will say as long as things are kept up it's not bad.
In a perfect world all of my machines would have been new{I'm **** retentive when it comes to the care of machines}. I will add though, through carefull selection I have been a happy owner of some good pieces of equipment that have cost me nothing other then oil changes, fuel and grease. Not saying things won't break etc... but with proper care and "operation" the cost can be kept low especially if it's only for personal use.
Couchsachrga; from what I'm reading it seems you have things under control. I would like to write one more thing that I learned. Renting an ex doesn't seem like much until you start renting more and more. I soon relized by the time I was done renting I could have bought and saved, this is why I now own excavators:). Plus I don't have to worry about weather, delivery, shape of machine etc...
4800 PSI Hydraulic Hoses/CAT Hose (A57454)
4800 PSI Hydraulic...
2018 John Deere TX (A53317)
2018 John Deere TX...
2006 Pace American MW8516TA2 T/A Enclosed Concession Trailer (A56859)
2006 Pace American...
Dewalt DW723 Rail (A57454)
Dewalt DW723 Rail...
2019 Chevrolet Silverado 1500 Pickup Truck (A55973)
2019 Chevrolet...
MACK DUMP TRUCK (A59823)
MACK DUMP TRUCK...
