Tractor -> Acreage Ratio
/ Tractor -> Acreage Ratio #21
3020 65 hp use with the 13.5' Rhino sometimes
1530 42 hp use with the 13.5' Rhino sometimes
1020 38 hp loader work
3720 44 hp
420 28 hp 72 mmm from 950
60 6 hp
56 8 hp briggs repower
231 hp / 6 acres 38.5hp/acre
7 other old 2 cylinders I didn't count! Hopefully the 1020 & 1530 & rhino will all get sold before winter.
Average age 36.5 yrs old -nothing runs like a deere
/ Tractor -> Acreage Ratio #22
ranch,
3030LS 88hp
820 32hp
town,
110tlb 43hp
4520 60hp
L130 23hp
ranch 490 acres
town 2 acres
492/246=2hp/acre
But in town I have 126hp/2=63hp/acre:D
/ Tractor -> Acreage Ratio #23
jd 790 27hp
26 acres of ornamental trees 'A 10 year row crop per field more or less'
27/26=1.03 hp per acre:D
Seems like minimal HP but most of the work is tilling, planting and harrowing the new planted field the summer of the first year. After that first year, most work is done with a blast sprayer that sprays a 60 ft. swath for insects once a month threw the summer. Plus some pre-emergant put down in the spring with the boom sprayer. Can blast spray everything in one day when all goes right. With the boom sprayer it differs because of the weather that time of year, but average two to three days. Have not felt under-gunned at all. Have felt a little sun burned at times.....​
/ Tractor -> Acreage Ratio #24
Case Tractor 50 HP (I think)
Kioti 41
Craftman 26
Troybuilts 8 + 6.5 = 14.5
One horse named Katie = 1hp
HP total: 132.5
Acres 8.6
15.4 per acre
/ Tractor -> Acreage Ratio #25
I've never taken the time to really consider this question... maybe 'cause I'm beginning to wonder if all the "stuff" I've accumulated is getting to be "over-the-top"! :D
But.. for the sake of "analysis" --
JD 110 - 43hp
Ford 9N - 28hp (I think)
JD X300R - 17hp
88hp/30 acres = 2.9hp/acre
I included the X300R 'cause I use to fert, mow and spray weeds on the horse pastures as well as the 10 acre hay field (spray weeds).
AKfish
/ Tractor -> Acreage Ratio #26
I feel a lot better that I am not the only grossly overpowered participant or hobbyist:
JD 1435 re-powered from 24hp to 36hp.
JD 2320 24hp.
Bunton 17 kawasaki 54" walk-behind.
All squeezed into my 16X20 barn.
All on my half acre lot. (77hp) or 154 hp per acre.
With all this hp I spread the wealth and help my neighbors for a total of about 3 acres worth of land.
Do I win a prize?
GJSnow
/ Tractor -> Acreage Ratio #27
GX 255 = 20 hp
3520 = 37.5 hp
Husky Chainsaw = 3.2 hp
26.97 hp per Acre
Guess I need some additional acreage?:laughing:
/ Tractor -> Acreage Ratio #28
JD 2320 24hp.
Do I win a prize?
GJSnow
geez, that is a lot of extra horsepower
/ Tractor -> Acreage Ratio #29
Wait a minute! I didn't even count 20 hp "lawn tractors" because they aren't actually tractors. Now I see guys counting Craftsman lawn mowers, chain saws etc. Heck, if I wanted to count the dozens of Stihl powered equipment, lawn mowers, generators and other things that have an engine and produce HP, I'm sure I could add another 1200 to 1500 hp to my mix. I thought we were just counting tractors.
/ Tractor -> Acreage Ratio #30
JD 6715 - 125hp
JD 6420 - 110hp
JD 5085m - 85hp
JD 5420 - 81hp
JD 5310 - 64hp
JD 5225 - 56 hp
JD 5200 - 45hp
JD 4700 - 48 hp
CIH 274 - 30 Hp
2x 245 - 35Hp = 70hp.
All of these are in Engine Hp.
= 714 / 80 acres = 8.925 Hp an acre...
/ Tractor -> Acreage Ratio #31
Versatile 895......315hp
Versatile 876......300hp
Steiger bearcat...210hp
Ford TW20.........154hp
Ford 7600............95hp
MF 390 ...............81hp
JD 2030...............68hp
MF 165 ...............58hp
Fordson major ......50hp
Gas major.............45hp
Cat D7e...............180hp
Case 580b............55hp
1427 acres / 1612 hp = 1.12 per acre
/ Tractor -> Acreage Ratio #32
DAYUM, thats lots of power, I only got 714 :(:licking:
/ Tractor -> Acreage Ratio #33
Kubota B2620 (26HP)
11 acres
2.36 hp per acre
They used to do ok with a mule on 40 acres so I'm golden.
/ Tractor -> Acreage Ratio #34
While a mule may be smarter and will step around and over the plants, my tractors follow instructions better.:laughing:
/ Tractor -> Acreage Ratio #35
Hard to do this with farming though as at least 1/2 the work is done by other machines such as combines grain trucks and swathers ,Which would alter it considerably ?
If i added -
IH 1688 combine........270hp
IH 1480 combine........240hp
Hesston 8110 swather..75hp
GMC brig tandem........280hp
Ford L9000 tandem.....350hp
Would get 2827hp = 1.98 per acre ....I'm still surprised it's such a small number !
/ Tractor -> Acreage Ratio #36
Hmm.... when will you learn it's not the size of the tool but how you work it that counts:thumbsup:
50/215 = .23 hp/ac
Here's a photo of me carrying an absolutely immobile post hole and fully braced corner which won't rot or rust, when I set it down .
/ Tractor -> Acreage Ratio #37
/ Tractor -> Acreage Ratio #38
50/215 = .23 hp/ac
What is with the pvc pipe? Do you have a toilet in your cab too?:laughing:
/ Tractor -> Acreage Ratio #39
That's 2800 lbs of concrete surrounding the post hole, but you knew that. :thumbsup:
The white PVC on the tractor(by the door, stuck in the loader crossbar, etc) holds chains, a 3lb sledge hammer, whatever fits.
/ Tractor -> Acreage Ratio #40
Wait... Should I count the entire property, or leave out the portion that I'm renting out?
Ford 1510......23hp
120 acres
23/120 = .19hp per acre :shocked:
If I leave out the rented ag field, it looks a little better (60 acres of crop may not be much, but it pays the property taxes! ;) :
23/60= .38hp per acre
PORTA POTTY (A68842)
Unused 2023 USA Attachments Quick Coupler Excavator Attachment (A66734)
Unused 2023 USA...
2025 Pabreak 78in Rock Bucket Skid Steer Attachment (A66734)
2025 Pabreak 78in...
2000 Ford F-250 4x4 Service Truck (A66736)
2000 Ford F-250...
2010 MACK TITAN (A67714)
2010 MACK TITAN...
Unused Hustler Standard Style Loader Kit (A66734)
Unused Hustler...
