Traction Traction is all about balance
   / Traction is all about balance #31
The idea of just backing in and lifting sounds fantastic. I always have to jiggle and wiggle to line up pins. Once the side pins are in the weight almost balances for the top link, however if I switched to a concrete weight I would embed a chunk of predrilled 2 1/2" square tubing for a receiver hitch in the rear.
   / Traction is all about balance #32
Doc_Bob said:
Where did you get the parts?
Bob
I fabed a frame using 2"x2"x.25" angle and 1.5"x.25"flat iron. I welded cat.1 hitch pins to the angle,then built a form for the concrete out of pywood.The flat iron sticks out the back,is drilled and serves as a drawbar,there is a clevis on it in the picture. There also is a 45 degree brace from the flat iron to the angle iron that goes up to the top link.The pins came from TSC.
Here is a very small drawing of it.If you open it it's almost visible.I dont know how it became so small.
Dump Truck Body with Tarp System (A55851)
Dump Truck Body...
2002 International 9200i Truck (A55315)
2002 International...
2006 Volkswagen Jetta Sedan (A55758)
2006 Volkswagen...
20357 (A55758)
20357 (A55758)
23013 (A55787)
23013 (A55787)
KUBOTA SVL75 ENCLOSED CAB (A52706)
KUBOTA SVL75...
