Tracked vs tires on Mahindra?
   / Tracked vs tires on Mahindra? #1
antryan
Can-am
Hi,
Does anyone know if there is a track that might fit a Mahindra 85P? I'm assuming a third party might manufacture a track kit that might fit but I haven't found any online.
Would a tracked or quadtrac type system assist with towing on 25/30 percent steep slopes?
   / Tracked vs tires on Mahindra? #2
Mahindra mPower 85P​
Dimensions
Length:165.9 inches
421 cm
Width:81.4 inches
206 cm
Height (cab):108.2 inches
274 cm
Weight:8177 lbs
3709 kg
Mahindra ML285 Loader
Loader weight:2090 lbs
948 kg
Mechanical
Chassis:4x4 MFWD 4WD
Steering:hydrostatic power
Brakes:wet disc
Transmission:12-speed synchro shuttle
   / Tracked vs tires on Mahindra? #3
   / Tracked vs tires on Mahindra? #4
Hi,
Does anyone know if there is a track that might fit a Mahindra 85P? I'm assuming a third party might manufacture track kit that might fit but I haven't gotten any seen any online.
Nice to have you on TBN with us antryan. Have you checked Soucy for a pod kit? Tracks will give you better tractor but also raise your tractor and its center of gravity a bit. Sorry I can't give you more info than that.
   / Tracked vs tires on Mahindra? #5
I don’t think a 85P has enough butt to roll tracks and a heavy 3 pt attachment.
2014 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2014 Ford F-150...
2019 NEW HOLLAND TS6.130 TRACTOR (A51406)
2019 NEW HOLLAND...
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
JMR 72" Root Grapple (A50121)
JMR 72" Root...
New Holland 3930 (A50120)
New Holland 3930...
New Wolverine Skid Steer 3pt Hitch Quick Connect (A53002)
New Wolverine Skid...
