Tracked vs tires on Mahindra?
   / Tracked vs tires on Mahindra? #1
antryan
Can-am
Hi,
Does anyone know if there is a track that might fit a Mahindra 85P? I'm assuming a third party might manufacture a track kit that might fit but I haven't found any online.
Would a tracked or quadtrac type system assist with towing on 25/30 percent steep slopes?
   / Tracked vs tires on Mahindra? #2
Mahindra mPower 85P​
Dimensions
Length:165.9 inches
421 cm
Width:81.4 inches
206 cm
Height (cab):108.2 inches
274 cm
Weight:8177 lbs
3709 kg
Mahindra ML285 Loader
Loader weight:2090 lbs
948 kg
Mechanical
Chassis:4x4 MFWD 4WD
Steering:hydrostatic power
Brakes:wet disc
Transmission:12-speed synchro shuttle
   / Tracked vs tires on Mahindra? #3
   / Tracked vs tires on Mahindra? #4
Hi,
Does anyone know if there is a track that might fit a Mahindra 85P? I'm assuming a third party might manufacture track kit that might fit but I haven't gotten any seen any online.
Nice to have you on TBN with us antryan. Have you checked Soucy for a pod kit? Tracks will give you better tractor but also raise your tractor and its center of gravity a bit. Sorry I can't give you more info than that.
   / Tracked vs tires on Mahindra? #5
I don’t think a 85P has enough butt to roll tracks and a heavy 3 pt attachment.
2008 Ford F-250 (A52748)
2008 Ford F-250...
Lot of Nissan Engine and Transmission (A50325)
Lot of Nissan...
COOPER LIGHTING CAT. NO. MHEP-22/28-175-MT (A52748)
COOPER LIGHTING...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2016 Ford F-150...
2015 INTERNATIONAL MA025 (A52472)
2015 INTERNATIONAL...
(INOP) NEW HOLLAND L328 WHEELED SKID STEER (A51242)
(INOP) NEW HOLLAND...
