track too tight
   / track too tight #21
Another way to help loosen track tension after you take the check loose is to back up with a piece of firewood between the track and the sprocket just take it slow
This is how I loosen up the tracks on my rubber tracked crawlers to replace them. I used a piece of 4x4 and walked it between the track and the sprocket. It worked like a a charm. I tried every other which way to move them including come-alongs and pushing with another machine with no luck.
   / track too tight #22
You think that world like a charm try using pins that are the same size as the space between teeth on the sprockets, walk them In, it's lifts the track off the sprocket and helps it slide right off, then use them to install the new track
New/Unused CFG Industrial QK16R Mini Excavator (A57453)
New/Unused CFG...
2018 Bandit 15XP Wood Chipper (A57453)
2018 Bandit 15XP...
2007 Mercedes Benz S550 (A56859)
2007 Mercedes Benz...
Hyster H80FT 8,000LB Forklift (A56857)
Hyster H80FT...
2018 Peterbilt 389 Wet Kit T/A Sleeper Cab Truck Tractor (A55973)
2018 Peterbilt 389...
202479 (A54757)
202479 (A54757)
